HAF X - Final Build with NZXT cables - Pictures Resized
2 Jun 2006
London / Essex Border
Intel Core i7 Extreme Edition 975 3.33GHz Processor
Corsair H50-1 High Performance CPU Watercooler
Asus Rampage II Extreme Intel X58 PCI-Express DDR3 Motherboard
Crucial 12GB DDR3 Ballistix Tracer (BL3KIT25664TN1608) 6 x 2GB
2 x Gainward Nvidia Geforce 480 (1536MB DDR3)(PCI-Express V2.0) in SLI Mode
Creative Sound Blaster X-Fi Titanium Fatal1ty Champion Series PCIe
OCZ Agility-EX 60GB SATA-II SSD
Western Digital VelociRaptor 300GB 10000RPM SATA-II 16MB Cache
Pioneer DVR-212BK DVD-R/W
Pioneer BDV-202BK BD-ROM
Enermax Revolution 85+ 1050Watt PSU
Coolermaster HAF X Gaming Tower
Logitech G15 Gaming-Grade Illuminated Keyboard
Microsoft Sidewinder X8 Gaming Mouse
Dell Ultrasharp 2407WFP 24" Widescreen LCD Monitor
NZXT Cables
Red
Looks real nice red.
Looking at getting one of these myself in next few days, quick Q for you though.
What would you say the minimum length cable for the atx 12V would be?
The PSU I am looking at getting has a 530mm cable and a bit concerned it won't make it up there behind the motherboard.
why have 3 threads for the same thing??
anyway your psu should be the other way, fan facing down. hence the air vents on the bottom of the case.
Well u get a ATX 12V extn with the HAF X
and this is NZXT cable i got from overclockers
http://www.overclockers.co.uk/showproduct.php?prodid=CM-001-NX
Are you sure, but then again I like it that way...And HAF X Manual has it that way round...
Yes, he's correct. I have the PSU fan down in my CM HAF 932. As said, that's why the vents are in the bottom of the case.
Great setup BTW!
Coolermaster got that so right by hiding the PSU cables, i so hated that is my old case.
Thanks for the advice guys, going to look for a dust filter first before turning PSU other way round...
Cheers for that.
Just bought a XFX 750W black edition supply, just need the cases to come back into stock.
Cable may be OK without extending it as it's 530mm long.
If not will go with NZXT cable as it looks so much neater.
RE:
I cant see a problem with not having a dust filter where the power supply is placed as that gets blown out the back through the PSU but next to it there is another grill vent which needs a filter:(
With the other vents all having filters I have no idea why they didnt have something inplace for this part of the case.
Cheers
mrix
