I do want to check something with you guys though. I read somewhere that Fractal Design released a *2nd* revision which has a longer backplate hole and uses different bitumen which doesn't smell. I have obviously got the old version which is annoying as I think the second one came out in March time.
Could some of you with the R2 who bought since March check if yours looks like this at the back:
The thing to look for is the left hand ridge below the cut out plate connects directly to it, whereas there is a gap on the first version of the case.
It may be that the new version isn't shipping in the UK yet. Hard to find out much information on it.
I'm mainly interested in the new bitumen they are supposed to be using now though and whether it really is much better and less toxic smelling than the first version.
This is the R2 I got from OCUK last month. Its the new revision with the larger backplate hole. Still smells of bitumen but then my room is pretty small. Very weak smell though not really noticeable apart from the first time i enter my room.
All the bitumen panels are coated in some kind of very thing plastic. Almost like those really thin plastic bags you get at the supermarket in the vegetable section. Dont know if this is the reason for the reduced smell or not. Glad this case isnt windowed though as the soundproofing is fugly!
Watercool it all!
