- 19 Oct 2002
- Torbay, Devon, UK
Can you get the qwerty version on O2?
Due for an upgrade next week and this looks nice.
Hmmm people that dont read. lol
Not coming to the UK at this time.
Not coming to the UK at this time.![]()
Well chuffed with mine.![]()
quick question guys.
has anyone had problems using the headphones with the SGS ?. i tried to watch a video using them but i had either no sound when the headphones are in or i get just one channel like background noise but no voices ??. the videos play fine and the sound is fine without the headphones. ive made sure all volumes are up in settings etc.... but still no joy ? dodgy headphones or jack ??
*UPDATE*
Just tried my headphones in a friends ipod and they work fine, so dodgy jack socket....
has anyone taken apart their SGS yet ? i work with electronics and circuit boards everyday so im pretty handy with a soldering iron if it comes to that.
In terms of what has been said above, I actually returned mine for Wi-Fi signal strength issues which got bounced back to me as 'no fault found'
However both with my HD2 and the wife's Milestone Wi-Fi reception was far less flakey.
I could literally stand next to my router and be on 1 bar where as with the other 2 handsets I can stand at the bottom of my garden and have full strength.
The Samsung couldn't even find my network anywhere in my garden.
Simply could not live with it so I've sold it on but without that problem it would have been a superb handset.
JF5is the best fro the lag , the lag fix only works for a while. Froyo version that i'm running is fine with regards to lag , however calender and stock browser are a no no.
SO you need to put with dolphin HD browser and no calender ATM
How did you manage £15 a month out of interest? I'm with T-Mobile and need to change my G1
Why not just get another one if you liked it so much?
It was obviously flawed or there was an issue with the router settings that rubbished the signal when connected to the phone.
Did you try it on other routers, and compare it with another Galaxy S?
Well worth it a lot faster no lag issues gps is better. Phone is just generally quicker. Back up current Rom up with Rom manager if your not 100% certain
How does Rom Manager work? Does it simply create a file that contains a complete backup of your existing system and software and settings, therefore, If I use Rom Manager to backup now, then flash to a new firmware, If I dont like it I can flash the Rom Manager backup and thus restore my phone to how it is now, with all my settings/apps and widgets??
Does it create said file on the external SD card or do you have to connect to a PC?
There are so many guides and how too's ... it gets confusing![]()
