Jailbroken iPhone Screenshot Thread
Tried Lockinfo last night and couldn't get the weather to appear / refresh. Any ideas ?
I had the same the second time I installed it (oddly, it all worked automatically the first time)- go to the default yahoo weather app and set a default location. Then go to lockingfo settings> plugins> weather> weather settings and make sure the location has been picked up.
After that it should update and show the weather on the lock screen, then you can go back and override the location if you want to.
Also the refresh interval is set to 1 minute by default, which seems a bit extreme unless you live in Tornado Alley!
ahh thanks, never used the default weather app so will try that tonight !
here's my Lockscreen for now will post my home screen later (still some tweaking to do)
Looking good ViRuS2k how did you go about doing that then? :P Also are you on IOS4 with the iPhone 4?
I touch 3rd Gen 64gb ;) ISO4.....
Here are some of the things i used.
Mac Battery - Find it on Cydia free
padlock tap to unlock - Find it on Cydia free
A266 Collection Theme but i used bits from it not all of it those include : 266 Icons Unlimited / 266 BossPaper Reveal
G.O.C Pro Theme but i used bits from it not all of it those include : Pro Itouch / Pro Ul sounds / Dock 1
Icons removal : use standard winterboard
no undocked icon labels / no docked icon labels
Infinity Folders - Cydia
This is nifty it will let you place more than apples standard icons in folders making it very good.
System Font to install it use Font Swap, the system font is called : Neutraface
Lock info - Cydia Displays the weather and other stuff tweak away, though you will have to download the weather plugin from within lockinfo or cydia.
make it mine : To change the Ipod into your own name on the status bar - Cydia free
and the wallpapers just ask if you need them
some of the things listed are payed for but if you want them all free dont ask me lol just google for repo`s ;)
My next theme that im useing currently ;)
will add more screenshots of new themes later :D
Theme : Ancient System v2,
The theme by the looks of it is based around stargate atlantis ;) love the battery 100% ZPM lingo lol
you will also notice the lockscreen has a finger print scanner and it actually works :D if you slide to unlock it wont work, if you tap to unlock it wont work :)
Fontswap, Neutraface....actually its not Neutraface but that is the most common one people use.
Thanks mate, I just tried to SSH it on the phone but how do I change the whole system fonts so they are similar? like the "Enter passcode" looks the same as the original Apple font :confused:
You need to replace the whole of the fonts folder for your new chosen one. Cant remember the the SSH location...but I think there are x4 files that need editing. If you do it manually you obv dont need to use fontswap either.
The finger thing works :S? How does that work out lol
I think cos im on IOS4 its not working as it uses another file .ttc ?
Thanks mate, anywhere to find the font? thanks
EDIT: I am running 4.0.1 on my 3GS and it still wont load up different system fonts so maybe this is causing the issue ?
Where did you get this theme from mate?
