- 4 Dec 2009
- Worcestershire
I was following this build log and the final product is amazingLeft:
Right:
Right:
thanks.... they look pretty sick. Might be a new purchase in the works.... IRL, does it look as purple as in the pic?
I must say, those fans are very nice indeed.
Did you purchase them from the Bay? As I cant seem to find any e-tailers I have heard of that stock them.
Here is the inside of one of my pc's.
Sorry, it's not a top class cam, just your run of the mill digital camera
I havent seen an IDE cable in a while...........![]()
Yep, I did and also from a third party e-tailer shop via a place that sounds like a famous rainforest. I've had a look and I can tell you that there are currently four of those available in 120mm size which is what mine are, all from the same e-tailer, the same 3rd party e-tailer I bought from last year. You'll find them on the dock of the bay and the rainforest. Just search for Blackfire 4 or AC Ryan Blackfire4. Can't find a blue-orange though, but the e-tailer could no doubt get you one.
AC Ryan Blackfire4 UVLED Fan - 120mm / UVBlue-Green £4.35
AC Ryan Blackfire4 UVLED Fan - 120mm UVBlue £4.35
AC Ryan Blackfire4 UVLED Fan - 120mm / UVGreen £7.89
AC Ryan 120mm BlackFire UV LED Blue Case Fan £2.99
w3bbo, that looks fantastic, very good job.
It kind of does really, yeah.
Got any pics of them at night mate ?
also are they loud ?
)omg is that a standard heatsink and fan, have not seen one of them in a long time
My lovely messy lian-li case. Wish i could get a modular psu and somewhere to hide cables.
Before you ask, the graphics card is a palit 4850 which was having issues in my girlfriends pc so i gave her my 4870 with scythe cooler and 'modded' the 4850 with the stock 4870 cooler sans fan + shroud and use the 120mm case fan at the side blowing onto it... works a treat if a tad unusual.
