New Patch Details
RE: 1.0.0.99 Release Notes Akali
· Twin Disciplines(Passive) will now gain 1% spell vamp for every 5 additional attack damage, up from 1% for every 10 additional attack damage
Annie
· Molten Shield now reflects damage to all normal attacks instead of just melee attacks
Anivia
· Flash Frost pass through damage will now break spell shields
Ezreal
· Mystic Shot attack damage ratio decreased to 1.0 from 1.1
Galio
· Idol of Durand
o Taunt radius reduced to 500 from 520.
o Damage radius increased to 520 from 500.
o Adjusted team colored range circle to more accurately represent taunt range
· Resolute Smite's particle will now more properly represent the area of effect
Garen
· Judgment now reduces the duration of new slows by 50% rather than granting immunity to slowing effects. Judgement will still completely clear any exisiting slows when activated.
Heimerdinger
· H-28G Evolution Turret
· Maximum turrets changed to 1/2/2/2/2 from 1/2/2/3/3
· H-28G Evolution Turret rank 4 now grants +100 bonus health to new turrets
· Cooldown modified to 26/23/20/17/14 from 24/22/20/18/16
· CH-1 Concussion Grenade no longer affects towers or buildings
· CH-1 Concussion Grenade ability power ratio increased to .6 from .55
Karthus
· Requiem mana cost reduced to 150/175/200 from 200/300/400
Kassadin
· Attack range increased to 125 from 120
· Magic resistance gained per level increased to 1.25 from 0
Kennen
· Electrical Surge ability power ratio increased to 0.55 from 0.45
· Lightning Rush
o Energy cost reduced to 100 from 110
o Lightning Rush now provides 10/20/30/40/50 magic resistance and armor for 4 seconds
· Slicing Maelstrom
o Ability power ratio increased to 0.4 from 0.33
o Maximum number of bolts increased to 6/10/15 from 6/8/10 (this still retains the cap of 3 hits per target)
o Removed the cap of applying only 1 Mark of The Storm per target
· Mark of the Storm (passive) stun duration reduced to 1 second from 1.25. Mark of the Storm has a diminished stun effect if applied more than once within seven seconds.
Kog'Maw
· Caustic Spittle has been remade and now grants:
o Passive: increases attack Speed by 10/15/20/25/30%
o Active: deals 60/110/160/210/260 damage and reduces the target's armor by 5/10/15/20/25 for 4 seconds
· Bio-Arcane Barrage cooldown reduced to 15 from 20
· Void Ooze cooldown reduced to 12 from 13
Malphite
· Seismic Shard
o Cooldown reduced to 10 seconds from 12 seconds
o Duration of the slow reduced to 4 seconds from 5 seconds
o Mana cost reduced to 70/75/80/85/90 from 80/90/100/110/120
· Brutal Strikes
o Changed the active effect to increase Malphite's armor and damage by 20/25/30/35/40% instead of increasing his damage by 30/40/50/60/70%
o Cooldown reduced to 16 seconds from 20 seconds
o Fixed a bug where the cleave percent would take double the amount of bonus attack damage
o Passive cleave percent increased to 30/38/46/54/62% from 30/35/40/45/50%
o The cleave passive will no longer proc while hitting towers
· Ground Slam
o Mana cost reduced to 60 at all ranks from 60/70/80/90/100
o Updated the tooltip to display how much bonus damage Ground Slam gains from armor
· Unstoppable Force is now unstoppable and cannot be interrupted by disables
· Granite Shield (passive)
o The shield now recharges after 8 seconds instead of 10 seconds
o The shield will now automatically restore to full after 8 seconds of not being hit. Previously it would not replenish until a new shield activated
o Fixed a bug where the shield particle would not appear for a second after the shield activated
o Fixed a bug where the shield strength would not update after buying a health item until a new shield activated
· Updated recommended items
Nidalee
· Fixed a typo in Javelin Toss
Nunu
· Base attack speed increased to .613 from .558
Pantheon
· Fixed a typo in Pantheon's lore
Poppy
· Devastating Blow now cannot be dodged
Nasus
· Siphoning Strike now cannot be dodged
Ryze
· Fixed a bug where Spell Flux was doing less AoE damage than intended when used in combination with his Arcane Mastery ability
Shaco
· Deceive
o Cooldown increased to 11 from 10
o Duration to 3.5 from 4 seconds
· Hallucinate
o Cooldown increased to 100/90/80 from 90/75/60
o Duration reduced to 18 from 30
o Guardian Angel no longer revives the clone although will apply the passive particle
· Backstab (passive) bonus damage reduced to 20% from 25%
· Two Shiv Poison no longer blinds the target
· Jack In The Box will now break stealth upon cast
Shen
· Feint duration increased to 2.5 seconds from 1.5 seconds
· Stand United no longer shields Shen
Soraka
· Starcall mana cost reduced to 40/50/60/70/80 from 42/54/66/78/90
· Astral Blessing mana cost increased to 90/110/130/150/170 from 80/100/120/140/160
· Infuse will now infuse half of the mana value to the target, and half of the value to Soraka. Soraka will get the full benefit of Infuse when she casts it on herself.
Vladimir
· Transfusion cast range reduced to 600 from 650
· Tides of Blood buff duration increased to 10 from 8
· Tides of Blood cast range increased to 620 from 570
Items
· Elixirs will now activate immediately if purchased when your inventory is full
General
· Summoner Cleanse now removes Silence and Blind effects
· Death Recap has been reprioritized to be more relevant to what caused a player's death
· Bots will now properly respond to Taunt
· Improved loading time by up to 25%
· Users with slow machines should no longer be kicked out of the loading process if they take longer than the server expects
· Added an option to turn of the snow particles on Summoner Rift (Winter)
· Added two ignore options: "/ignore ally" for ignoring the allied team and "/ignore enemy" for ignoring the enemy team
· Line Missile targeting status now is properly represented in the options menu
· Fixed a bug where mavity based spells would not immediately apply damage
· Fixed a bug where the HUD scaling option would not work the first time the game client loaded
· Fixed a client crash that would occur when loading into the game with a key pressed down, which was commonly occurring when using third party applications such as Ventrilo or Teamspeak
· Fixed several client crashes
· Fixed several server crashes
Annie
Anivia
Ezreal
Galio
· Idol of Durand
Garen
Heimerdinger
Karthus
Kassadin
Kennen
· Lightning Rush
· Slicing Maelstrom
Kog'Maw
Malphite
· Seismic Shard
· Brutal Strikes
· Ground Slam
Nidalee
Nunu
Pantheon
Poppy
Nasus
Ryze
Shaco
· Deceive
· Hallucinate
Shen
Soraka
Vladimir
Items
General
