Mmmm, might have to charge my greenforce up and take a piccy later.
Diving torch though so can't keep it lit for too long out of water.![]()
Aaa the joys of diving torches, eye wateringly expensive and always seem to bloody leak on me
. In real world it doesn't look bad at all.
Help me if you will. I need to choose a torch that has a nice long throw (while also being able to offer a wide flood if need be) and for under £70ish. Like the look of the Fenix torches and have heard good things about them. Want something that will also clip onto my belt ideally. What should I be looking at?
Cheers
Nice, I'm surprised that 5mm LED's can produce so much light. Would the drop-in also work on a C sized Maglight? Also, I may use 18650's so I'm guessing 2 in series would give a good voltage (between 7v and 8v)? Where can you buy this drop in and how long is the battery life when using AA's?The maglite is a beast of light for the money paid. I reach for it for all things bump in the night, having 100% flood is great for filling an area within 50 metres with light. Indoors it sets a room alight with light. - if you can live with the blue tint. In real world it doesn't look bad at all.
Just bought another torch as I wanted one that takes 18650 batteries and now I'm wanting an Olight SR91 @ £250
3-9v sounds ideal. I'm already running 18650's in my 2C maglite, and it works fine. I had to remove the spring but a blob of solder in the tailcap works well. Right now I'm running a maglite bulb from the 6D model as it works well at 7-8v.It is quite surprising how much light it chucks out for with it using 5mm LEDs. The module will handle anything between 3v-9v. The AA to D cell adapters I am using are two of these .
I am not too sure about fitting 18650's into a 2C maglite. Might need to take a look on CPF![]()
Is this the module you used:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120621854529
I'm quite tempted to order one now as it should be quite a nice upgrade. Roughly how much battery life do you get when running AA's?
Ordered.That's the one! It looks like they are offering a warmer version of it. Think I may have to snap another one up soonish!
I get around 1hr 45mins runtime on 6x AA 2100mAh Uniross Hybrio.
Post some beamshots if you get one!![]()
I hope it does actually use Nichia K1 LED's, as many of the cheaper LED's from China tend to fade relatively quickly. My 18650's are around 2200mAh so I should hopefully get a similar runtime to you, almost 2 hours is rather good I think!Ordered.I hope it does actually use Nichia K1 LED's, as many of the cheaper LED's from China tend to fade relatively quickly. My 18650's are around 2200mAh so I should hopefully get a similar runtime to you, almost 2 hours is rather good I think!
I'll post some beamshots once it arrives.
How has this thread made 5 pages.
it's only 2 pages. But it's still 2 interesting pages, better than the usual, woman threads
