- 6 Feb 2010
If you are sticking with 1680x1050, then just grab a 2nd hand GTS250/HD4850 512MB for around £40 to tide yourself over till the next gfx upgrade, or try to find a 2nd hand GTX260 or 4870 1GB for around £70 or 4890 or 5770 for £80.
Anything that cost more than that, it simply doesn't worth dropping from the GTX460 768MB, as the chunk of performance you loses is simply really not worth the little money you are saving...
. Good luck unlocking the extra cores.
