Running fine on mine. Give me a bit and I'll upload it.
edit - here you go.
http://www.megaupload.com/?d=UBORVFJL
cheers!
edit - here you go.
Can android sync with exchange for free ala WinMo/BIS/iOS/Symbian?
Just wanted to know cos I'm trying to swindle a few of these bad boys out of our account manager at work.
Yes, all versions, push email, calendar and contacts
It's where you can bake your own custom roms with just the features you want on it, i.e strip out all the Orange stuff, add in things like the HTC IMC keyboard etc..
You select a bunch of tick boxes, hit bake then you download your customised ROM ready for application. You need a Modaco subscription though to access it.![]()
Until Devs get their hands on the Kernel source (fingers crossed it will be soon!) there won't be any leaps and bounds, it's just pretty much standard android with the bloatware gone at the moment.R3 installed
Not seeing much difference really, waiting for 2.2!!
I've managed to get A2SD working! I almost jizzed myself when I realised the almost infinite amount of apps I can now install!
I checked the option in the Modaco online kitchen and it seems to be working great.
Just tested and I'm having the same issue.Is your ZTE provided Task Manager working? Mine shows the app data as unknown, then crashes when you hit the resource tab. Only started doing this post a cooked r3 ROM with A2SD.![]()
has anyones button (switch on) become a bit loose, its not the switch its the button cover
Just tested and I'm having the same issue.![]()
Has anyone as a current orange customer managed to convince them to drop the price any on this handset, just tried myself but didn't succeed. If so how?![]()
