Does anyone have any recommendations for headlight plastics that have turned yellow/cloudy?
Thanks![]()
I could use a little advice. Have been trying to correct a mates Focus which has been subjected to serious mechanical car wash abuse by the looks of it. Anyway I found that even Megs 105 on the most aggressive pad I have wasn't giving a great finish, 90% of the swirling gone, but there's enough remaining so that it still looks mildly swirly.
I'm thinking maybe it's the pad, just the white one that came with the silverline machine. I don't usually need to use harsh pads, hence I've not bought a better one. You guys think this could be the issue?
Thanks, she was a beauty, an amazing car in every way. Back then I had the time to look after her, and drive her the way she was intended for. Life and motorway mileage caught up with me, so I had to let her go before she sufferedDC2 looked really nice Floyd!
Snow Foam...talk to me! Wheres best to buy these lances/the actual snow foam, and what benefits does snow foam have over conventional shampoo washing?? I always see pics of peoples cars covered in the foam, but never looked into it lol
What stuff do you cleaning gurus recommend
I've got a couple of microfibre cloths
But the wax in the olde family shed is old stuff
If I go to halfords with 40 notes what should I get?
Strictly beginner stuff really I've never really properly waxed a car
Ok so my list is
Meguiars gold class shampoo conditioner
Meguiars carnauva wax
A sheepskin wash mitt ( i presume you use this to put on the shampoo yeah?)
I went there earlier and couldnt see applicating pads or towels though?
I went into a Halfords the other day to buy more pads and they didn't have anything. I think only the larger stores stock them.
http://www.halfords.com/webapp/wcs/..._productId_201965_langId_-1_categoryId_165609
Will be the same with towels.
http://www.halfords.com/webapp/wcs/..._productId_248846_langId_-1_categoryId_165609
If its anything like my paint, its silly soft and you're probably re-inflicting the marring.
Fair enough
Got the pads and towel though
Is this the wax you ment peter ?
http://www.halfords.com/webapp/wcs/...&productId=201921&categoryId=165527&langId=-1
Why are people saying this? I've already said that the fine swirling is gone and just the deeper stuff left. I've only ever done Jap OE and cheap refinish paint before so I know a thing or two about soft paint and hologramming. This is nothing like that.
