hmmm How long is the card? I currently have a gtx260 and that just squeezes into my antec sonata case.
Hi.. The card is actually slightly shorter than a GTX 260 (which is what I previously had).
The actual PCB comes in at approx. 225mm and yes the fan shroud does overhang this by approx. 15mm. Thus making the card at its longest point approx. 240mm.
Though as commented before, the power connectors are at the end of the card, rather than on the side. Which may be an issue for anyone that's a bit tight for space.
The 260 GTX comes in at approx 265mm.
So I would have thought if the 260 fits in your case, then the 460 HAWK should be OK.
Hope that helps.
There is a picture of the HAWK fitten in my Lian Li case earlier in this thread. See post no 41 page 3 of this thread.
Hi, was it a worth while upgrade from a 260gtx, iam tempting to upgrade,atm i have gtx 280, is going to a 460 worth it??
Any chance of a price cut soon MSI-Guru?![]()
Bascially id MSI drops the price of the HAWK down to 160 pounds then they would have 2 sales here instantly
the question i'd like to ask msi-guru is that i buy a talon attack and put it in sli with my normal HAWK. and i over clock my HAWK to talon speeds. will both run a talon attack speeds? an answer would really be welcome!!
. Also depends on your definition of "stable" as well (but I don't want to go there... as they say).PS. Also interesting to see that they are using yet another beta version of Afterburner to do their overclocking at Kitguru. Though I see that there is already a beta version of 2.1 doing the rounds as well. Whether this makes any difference, who knows. Though as I've commented before, some of the reviews of the HAWk version of this card used a version of Afterburner that allowed up to +200mV to be applied, which in my opinion gave a bit of a false impression of it's overclocking potential. Though I'm also aware that some have used the official final release version of Afterburner 2.0 (IE. up to +100mV on the core) and achieved decent OCs. Also as commented ad nausea, it's pretty much luck of the draw, or should that be "luck of the core". Also depends on your definition of "stable" as well (but I don't want to go there... as they say).
Just waiting for a TWO @ £150 or less.
hint hint.
EvoBeardy
I tend to agree with pretty much what you say.
What I was actually getting at, is that the final release of AfterBurner had the max voltage increase that can be applied to the HAKW reduced to +100mv. From talking to Unwinder on the Guru3D forums, this was because MSI told him to set it to that. I suppose that they are just wanting to play it safe and trying to reduce the possible RMA's from blown regs.
I noticed that one guy on the Guru3D forum also managed to blow a reg by pushing to much voltage through it! Now I wonder if he managed to get a successful RMA on it? I might post and ask him. You've got to laugh sometimes.
I'll also be interested to see if the PCB has been changed in any way (EG. heat sinks on the VRM's... which the standard HAWK doesn't have).
Good luck what ever you decide to do and I'll be very interested to hear how things go. So keep us posted.
