Slowly reading these points and responding - so bear with me - also dont think Im not pointing the finger at myself...
i think generally we play too direct passing style. I think this is passed over from fifa 10.
Partially disagree - I think certain people still play like its FIFA 10 or if its 5 star 1v1 game they are playing - I wouldnt say as a whole what we do has any bearing on FIFA 10, but when we get desperate we do devolve our play to that far too easily...
I'd rather we worked the ball into positions where there is an opportunity. I think we do that sometimes if there are 5 or 6 on.
But for me we dont pass it back enough, we dont pass it around enough, we dont pass to the CPU enough (if you dont trust cpu then just request it back from them straight away)
Agreed - not all passes have to be forward, but Id rather them be short and precise (far too many passes are intercepted or ground through balls that your VP isnt capable of doing or constantly poorly aimed crosses - learn what they can/cant do and if you dont like it, level them up) so at a minimum we retain the ball. I dont think passing directly back to CPU helps because whoevers hounding you will run in the same direction they were to you to hound them (notice kick offs). Playing width seems a better solution...
Regard pressing X. If im in midfield rcm or lcm then yep ill be pressing X a lot . Its midfield job to get ball to strikers...not strikers job to get ball from a defender in a hopeless long ball.
If im in striker ill sometimes press X (or triangle) if i am in huge amounts of space and its a clear chance (if done this a couple of times and both times didnt lose the ball). I'll also press x from the goalkick if i think i can win the header.
Not pressing X also leads to problems where the IDIOTIC cpu loses it in crazy positions.
One of the main reasons I expected people to train their VPs to get a better understanding of teamplay (this isnt scoring or just providing the killer pass) - it doesnt seem to have worked. We never got the x request situation 100% sorted in FIFA 10 and I doubt we will in FIFA 11 - I have to hope in time and learning how people play will help.
I do agree that midfield should serve the forwards, but really we should be trying to get to a situation where when you ask for the ball you know who is around you from our team, what they are probably gonna do once they see you with the ball. Quite a few of the chances we made is when the the early pass/cross and given it rather than waiting to go past some imaginary line which then allows them to cross or get closed down before they decide to pass...
People know if Im ST and the ball is on my wing that Ill go wide to support even if it means me crossing, I shouldnt do it all the time and I try not to but at least its an option. I know if Skips up front and Im mid he will generally do the same and overlap me and give me that same option.
While I remember can people stop asking for it from the goal kick if you havent already realised that the GK kicks it short every time you ask for it, when I was CAM I kept getting the goal kick because my ST was repeatedly asking for it while they were running up the pitch to their position. When you ask for an x request the GK and invariably CPU player will pass to where you pressed it, not to where you are seconds after you asked for it.
Ohh and we need ANY back...either rotation of any on perma basis or if someone wants it....coz CPU sucks...really sucks so bad its unreal.
I agree, the CPU is ****, but its a minor inconvenience when there are 5/6 people and it only has the defence to worry about, but we need to start using a Human ANY in other situations - I dont look forward to that because Im just not good enough and when Ive done ANY in FIFA 11 weve rarely got out of our half. If you think about it though, with us overloading the CPU with x requests and just being in crap places to ask for the ball its not really surprising that the CPU does as badly as it has. It makes sense that if you are ANY you set your VP as a defensive player to help yourself out...
Also has anybody noticed how reactive the defence is to the circle button when you are captain? I never hold it down now because its literally like playing 1v1 with me pressing x to tackle. Its actually far less difficult than FIFA 09/10 if you let the CPU keep the form and help it tackle when needed...
ps3ud0
