- 21 Nov 2004
Can you do the episodes at any level?
Have to be at least Lt6 for Devidians and Lt10 for Breen episodes I think? I could be way off though!
The current batch of episodes are doable by anyone of Lieutenant Grade 6 or higher. The Defra episodes are doable by Lieutenant Grade 10 (Lieutenant Commander 1).
The end of series reward for Defra was a Very Rare Breen Tactical Officer, which you can no longer get (although it may appear in the C-Store later).
So far there has only been 2 episodes in the current Devidian episodes, with the next episode appearing on Saturday.
Tactically everything is pants at VA level as most ships don't have dual Tactical officer slots.
The Refit Defiant does
I still have to respec my BO's a bit as I have Cannons:Rapid Fire 1, 2 and 3 on the same BO.
General
* Deep space encounters with the Hirogen in the Psi Velorum sector block were leading to encounters with the Terran Empire instead. This should now be fixed. (The Terran Empire is no longer sending disguised ambushes into Romulan space.)
* Groups of Undine no longer tend to stand in a straight line.
* The Synchronic Proton Distortion Rifle now has a more appropriate icon.
* Fixed a bug that caused mouselook to get stuck on forever when leaving/entering the gameplay state with both mouse buttons held.
* The sprint animation has been updated.
Ships
* Blinking navigation lights have been added to Sovereign class ships.
* Blinking navigation lights have been added to the Nebula.
* The floating node issues have been fixed on the vorcha C-store variant.
* Typos have been fixed in customization for the Vor’cha.
* The size of the Vor’cha’s shields has been fixed.
Missions
* By Any Means: The mission tracker now properly directs you to Station Alpha instead of Beta.
* The USS Nobel is now the correct Olympic-class ship in the Cirini Prime system.
* Devidian Weekly Episode 2: Spin the Wheel
o Belan is no longer quite as ornery before asking the player to fix replicators.
* The surface of Hotep IV is now a little more refined. Of note, there is no longer a pit to get stuck in.
* Textures on certain buildings on the surface of Defera now show textures at all distances.
UI
* The icon for Photonic Officer is now properly red if you’re part of the Klingon Empire.
* The icons for the various Marks have been adjusted. They now contrast more with their backgrounds.
* The chat window no longer minimizes when resizing it using the upper right corner.
* Master Loot UI works properly once again.
I stopped playing this time around bos I kept crashing on ground missions. I could forgive the fact that most missions were move from group to group of bad guys and kill them all in turn, but not when I had to do it over and over because of crashes![]()
STO any good?
I ain't played it at all. I wanted to buy it at release but coupled with the high price at the time, I didn't like the reviews it was getting.
