Do any of these mods add locations to the BG II map?
Could anyone put up the combined map with all locations?
Anyone know if its possible to use the no cd crack once the Big World stuff is installed? Want this on my netbook but obviously no DVD drive sadly and I've tried but couldn't get it to work, just wondering if anyone else had done anything similar?
Just installing this now....currently downloading all the mods.
Got it working now.
A few little differences from Neil's guide: I chose to update BiG World when I ran it, then let it run through the "Recommended" installation.
At the end, I didn't run Setup-ToBEx. Instead, just installed the Widescreen mod, then launched the TobEx Launcher. All works fine from there!
The Tobex Launcher works on it's own if you installed the recommended however if you followed my instructions it would need to be installed manually. Whatever way you do it my guide has less problems later on in the game.
But if you got working , well done![]()
Is it possible to install BG II on a netbook without a disk drive? I know you can get BGI from gog.com but how would I go about installing BGII + ToB. Even if I did get an external disk drive I wouldnt want to carry it with me the whole time just to play BG.
Thanks for the help...
