2x 6870 DOES NOT better a 5970.
YES IT DOES!!!! jezzz just because you own one doesnt mean you have to try to defend your rubbish purchase with some fanboi "purchase justification response"
worthless, uncalled for, non helpful insults
Hmm I will have to say that the 6870 in crossfire will slighty out run a 5970 at stock speeds.
But unleash the 5970 at 1100/1400 and nothing can touch it.
well apart from gtx480 sli.
all this childish behaviour over a gfx card
some of you clearly dont have enough to worry about it
It does when its overclocked.
Well yes. But they cost so much when you buy to its useless mentioning them
yes I did.
But again your wrong, at stock speeds 2X6870 are BETTER than a 5970.
They have better maximum framerates, better minimum framerates.
Why is it?
As for overclocking, been saying for days that if the 580gtx doesn't overclock better all you get is 6.5% more shaders, which likely won't give you much more than 4-6.5% more performance depending on the game. Now this card can't overclock properly, is limited and so is 5% faster. Epic failure for a card that was launched 3 times within 14 months.
At stock slightly![]()
At stock it's quite a fair bit faster, crossfire scaling is the important thing, not raw spec's, the 5970's scaling is pretty poor in comparison to SLI, and the new improved scaling of the 6XXX series.
And if people have the money, they'll get it.
you starting to back track now!!!! lol
try eating some reviews - http://www.techpowerup.com/reviews/ATI/Radeon_HD_6870_CrossFire/10.html
the crosssfire 6870 destroys a 5970 at high resolutions.
Read about this power throttle so as not to exceed the PCIE spec.
Seems to me that Nvidia have some ulterior motive and in essence, throttling is the only way they were able to impliment 512 cuda cores and hence get this card into production.
In reality, will this 300W throttle really affect the cards ability to overclock because if so, seems like Nvidia may have scored an own goal![]()
Cat 10.7 doesnt count so the review is worthless
I doubt any driver release will have help a crap 5970 improve enough to beat 2X6870.
why dont you find some reviews to back up your argument? thats right you cant!!!! lol lol lol lol
My pc is worth more then your house
