Is there a console so you can change certain settings precisely?
Like the mouse sensitivity?
yes and its enabled by default, dont know what key it is to open it but would hazard a guess at the ` key just left of the 1 key
I see you cannot bind the keypad keys...
Can anyone elaborate on this quote?
Please tell me thats untrue.![]()
Lag has improved loads since earlier, not having too many issues.
Enjoying it.
Do elaborate my copy is sitting in its wrapper untill its playable and fixed other wise i might just return it. (not flaming as i know its still early days i just want to make sure i do the right thing before i install.)
In the console, use 'connect 192.168.1.1:1234'. This is from my experience in all CODs up to MW1, shouldn't be different in BO. At least the console is enabled again, thats something.
Easy way to check FPS without third party programs aswell, 'cg_drawfps 1'.
Enjoying it.
I expected it to be at least as good as MW2, not a huge step backwards.At the whingers, what exactly were you expecting?
It's a tweaked MW2 with servers. Happy days.
