it keeps on opening a random webpage of msn live every now and then ????
I'll be going back to 2009 version it works so much better than 2011 which disconnects and reconnects, no nicknames!!
Doesn't that include all their silverlight and photo gallery stuff too?
If you want to give yourself no second name then open character mapper and tick advanced view, then with font Arial selected search for "narrow". Should only be one result which is a blank space. Then you can copy that into the second name field when you edit your name.
At the end of the day, there was no need to remove the nickname function anyway. It's not that you can get around it, it's a case of wondering why you should have to.
, and not because of a "worm"). Also seems to only need a single click on a link to open it in Firefox instead of at least 2 clicks as in 2009.
