Chest day today. Going to aim to do:
Barbell Press
Incline Dumbell Press
Incline Flies
What else should I throw in there? Cable Cross Overs?
Cables are good. Could even stick a bench between the cable setup and do flat/incline cable flyes.
Barbell Press
Incline Flies
Going to grab some straps and go for a 180kg DL tonight, wish me luck!![]()
Straps for me make the lift much much easier. But my grip is the weak link not my core, back or hamstrings..
Good luck
Straps for me make the lift much much easier. But my grip is the weak link not my core, back or hamstrings. RAW at the moment the most I've had up is 170KG. However with straps 190KG shot up. Before my break from deadlifting and easing up on my training 205KG would come up with straps.
I personally prefer the lift with straps as I can focus better on muscle connection and form but find RAW lifts more satifying.
Barbell Press
Incline Flies
Cheers!
I completely agree, a raw lift (163kg is my current max, completely RAW) is defiently a lot more satisfying.
A lad offered me a go with his straps last week, DL'd 135kg for reps with absolute ease and NO affect on my grip, was astounded by how much of a difference it makes, it always seems to be gripping giving way, not the strength of the back.
Will report back how I get on, guna go for(please critique);
60kg x12 warmup
100kg x 12
120kg x 9
140kg x 6
160kg x 2/3
180kg x 1
You could drop the reps a bit on the lighter ones... but it's up to you.![]()
Yeah true - 1/4 of a tonne does sound impressive. If I do it, I'll have to record it... problem is when I go to record things I never succeed!![]()
I know dips hit the pecs as well, but are they good to use on a dedicated chest day?
160kg for 5 is good squatting dude!!To parallel I trust though?
My calves struggle to grow![]()
Yep I'd do something like this:
60kg x12 warmup
100kg x 8
120kg x 6
140kg x 4
160kg x 1
180kg x 1
Calf muscles can be a bitch to grow for some. The soleus is a type 1 muscle fiber for fast twitch and yet the gastrocnemous (deep to soleus) is type 2 muscle fiber for slow twitch. So you really have to mix up slow heavy lifting with fast longer lifts.
