Ok guys please be patient with me. I know the more I ask the more you guys are getting
Everything before the clockwork mod thing makes sense.
However the clockworkmod section its self, is that the actual process of puting version 2.2 of the Os on the phone?
Using these instructions;
(Step by step install instructions:
* Download 2.5.1.3 ClockworkMod Recovery for ZTE Blade - DOWNLOAD (ROMraid Load Balancing) - MD5: 0733acd513717f2dc7ee08809bd7ea20
* Download fastboot if you do not have it already.
* Turn off your phone and take out the battery. Unplug the phone from the PC / charger.
* Replace the battery and turn the phone back on with 'volume up' held. The device will stay at the 'green android' screen.
* Plug the phone into the PC.
* Extract the fastboot zip file.
* From a command prompt (at the directory containing these new files!) run 'fastboot-windows flash recovery recovery-clockwork-2.5.1.3-blade.img' (subsituting 'fastboot-mac' or 'sudo fastboot-linux' as required)
* When this finishes, from the command prompt run 'fastboot-windows reboot' (again substituting 'fastboot-mac' or 'sudo fastboot-linux' as required)
* Done!)
Also is this the latest software?
Are these unofficial rom's stable? Im reading on Modaco forum, that some have instability......
What benefit does the 2.2 version have over 2.1?
