If theyre close enough that the knife "lunge" kicks in then they do seem to just zip through your shots and get the cheap kill in.
Does this work yet?
I've tried to play Campaign a few times, and it is unplayable. This is on a E6300 @2.8GHz, 2GB or ram and an ATi 4890.
Are you on windows 7 ? did you do the sound card tick box fix ?
yea the knife sucks, i do not know why they make the knife zoom forwards like that, seems like of stupid. The best knife is the counter strike knife that takes loads of hits before the person dies or if you use secondary it is very slow but can take one or two hits.
The 1 hit kill isn't the problem. Its the combination of the ridiculous heat seeking lunge and the fact the knife isn't a weapon in its own right and is instead just an instakill button. If you actually had to switch to the knife, which would take considerably longer than it does at the moment, knife wouldn't be anywhere near as bad.
Yes, Windows 7. I don't know of any fixes, so no, other than adding a few graphics tweaks to the config.
Not sure if this has already been said. It looks like they have found a fix for the stuttering, although i still have to do snd_restart at the start of every map to prevent the sound from being broken. The stuttering is gone for me.
Windows 7 only, Go to control panel, sound options and then right click go to properties of your default device.
Untick where it is highlighted in yellow and set the default quality to 48khz dvd quality. I can even set the fov to 80 now and it dose not glitch when i run or shoot someone, except for usual lag.
• Added an option to create shaders during load time. This fixes hitching when viewing a new area of the map for the first time on some video cards.
• Incomplete server browser results.
• Improvements to Quickmatch results (with better ping and reduced lag)..
• /connect
• /reconnect
• Improved threading performance on computers with only 2 cores.
• Fixed random freezes in certain computer configurations.
• Increased reserved slots to 9.
• Improvements to the spawn system to resolve an issue where negative spawn influencers from specific game events were not always being deleted after the danger had cleared – in some matches, this was causing good spawns to be erroneously flagged by the game as bad spawns, which in turn forced actual bad spawns to get selected later in the match
• Weekly and Monthly leaderboards will now track all kills, deaths and assists properly (All Time leaderboards were not affected by this)
• Prevention of killstreak selection getting disabled in Combat Training under rare conditions
• Array: Added collision to prevent players from partially clipping into a tree
• Launch: Added collision to prevent players from strafe jumping onto an invisible ledge at the base of the rocket near B3
• Summit: Added collision to prevent players from jumping to a location outside of the map boundary when in Custom Games where player speed is maxed out
• Havana: Added collision to prevent players from jumping onto an invisible ledge above a doorway at C2
• Nuketown: Adjusted a spawn point that would spawn players on top of a mannequin’s head when that mannequin was randomly spawned in that location
• Launch: User could access a small platform outside of the intended play space below the rocket gantry by jumping to a very specific location; now blocked from access
• Launch: User could access a small area inside geometry at vents near Dom flag A by going prone and moving around in a very specific location; now blocked from access
• Some users reported that weapon attachment challenges were not resetting after prestige; now all are guaranteed to clear as soon as selecting the prestige option
• Radar sweep when there are only 2 players left in One in the Chamber will stop functioning if the 2 players have multiple lives when the sweep starts
• Villa: User can clip into rock at west edge of grid zone B2 and see through to the other side
• Crisis: User can clip into LVT between grid zone A3 and B3 and see through to the other side
• User can get an infinite number of 'Sam Turret', 'Care Package' and 'Sentry Gun' killstreaks (commonly referred to as the “care package glitch”)
I'm upgrading my pc tomorrow. I want to keep all my settings \ achievements etc. Is it all held on the Activision servers and will be restored when I reinstall or do I have to back up some kind of folder then copy and paste over?
Thanks in advance.
