On play they are allowing pre order of white SF at 99.99 inc 10 credit.
They also quote OLED screen!
So does this guarantee that it will have the better screen?
Or a valid reason for return?
Is that Modaco Flib?![]()
I really wanted one of these but unsure if I should go for it now it has the TFT screen, as I'm worried about the battery life and display quality.
. As a first time smartphone user, I guess I wouldn't notice a great deal of difference in the OLED / TFT versions, but reading on the Modaco forums it seems some ROMS don't work with the TFT model which is a bummer. Or will the ROMS be tweaked for TFT in time?
Going to finally get one of these over the weekend, woo. As a first time smartphone user, I guess I wouldn't notice a great deal of difference in the OLED / TFT versions, but reading on the Modaco forums it seems some ROMS don't work with the TFT model which is a bummer. Or will the ROMS be tweaked for TFT in time?
I phoned my local Orange shop say they are unaware of the screen change but have a few in stock from a few months ago and have put one aside for me, might be OLED but they don't know.
Is there anyway for a phone newbie like myself to tell the difference between them?
Thanks in advance!![]()
From what I can tell (got the OLED one at the weekend), pure black images appear black on oled but are more of a lit up grey on tft. If not then go into the phone settings (the shop should let you have a look at it) and at the bottom to 'about phone' and get the build number, if it ends in 05 then its OLED but if its 08 then it could be either.
Will they not get arsey about breaking the security seal?
