Caporegime
- 9 Nov 2009
- Planet Earth
Maybe the Catalyst 10.12 drivers include a BIOS update for the cards to unlock the extra stream processors!
So it's a warranty-coverage switch?
The board ships with "warranty-coverage" set to "ON" and power-tune allows a limited set of TDP-defined performance options.
If you flip the switch, power-tune can be set wherever you like, but the warranty is gone (and the RMA dept. will have proof of what you did).
So you think this switch unlock all 1920 SP's, if true that's a 580 beater.
Seriously? GTX480 came out 6 months after HD5970 iirc correctly. It was Nvidia that had to fit it in the market, not the other way around. HD5970 is still the king of performance.
they will have the fastest single gpu card, pushed to its limits, if it goes **** up they dont have to rma it as their will be a disclamerand why will company will make such a product???? i believe that swith may have dual bios for reseting ur gpu bios or overclock it a little]
I still have high hopes for AMDs release this week, I genuinely can't imagine it would be a lemon, if not surely they'd just delay it furtherThanks for the info...
But the fact still remains, amd switched from making massive gpu's quite a few years back. And since then their answer to the high end has been a dual gpu board. Why should this launch be any different? All we have is rumour and for the most part slides that appear to have been tampered with.
Its going to be how it has been for the last while, 6970 will compete with 570 while the 6990 will give the 580 a good slapping.
the switch is for the dual bios
That's bull****, have a look at HD5970, 334mm2 x2. HD6970 is 389mm2 large as it stands, no matter if the performance figures are correct or not. That is a mahoosive difference evident in power requirements as well. Not massive you say?![]()
It would be quite frankly embarrasing if you have to turn a high performance BIOS on, invalidating your warranty in the process, to get anything remotely better than 5870 performance.
Believe what you want, come Wednesday we'll have the answers.![]()
6970 is a lot faster in tessellation, has 2GB of ram, maybe that's enough for AMD, just like it was for Nvida in renaming the 480's lovechild to a 580 even though it's clear it's a 485 at best.
