Unlock your ATI 6950 to a 6970 Thread
Caporegime
OP
24 Dec 2005
Autonomy
I got a buuble message saying display driver has stopped working and has now recovered:eek:
Does everything look ok? It seems odd that it doesnt display the current bios...?
I'm about to load the 6970 bin file
Caporegime
OP
24 Dec 2005
Autonomy
Ok I went for it it started and then a message appeared saying "could not erase rom"
I have the switch position in 1
EDIT: If you get an error like ID mismatch or Could not erase ROM, then you'll have to do some extra work in a command prompt: Run atiwinflash -unlockrom 0 followed by atiwinflash -f -p 0 bios.bin where bios.bin is the path and filename of the HD 6970 BIOS you downloaded.
Guess I'll have to do in DOS and make a Bootable USB :(
21 Oct 2002
Bexhill on sea
Had a look at the "techpowerup" article and right at the bottom it says "HIS" 3 tried, 3 successful unlocks, looks like these have a good track record. Already got one, and another coming in the post for Xfire hpefully by the end of the week.
He....Xfire 6970 for £426, bargain:D:)
Caporegime
OP
24 Dec 2005
Autonomy
Pyr0m@nI@]{;18083384 said:
ok, open the folder where you have atiwinflash, hold shift down and right-click in a blank area
you should see a menu item "Open command window here"
this will open a cmd window at that location and you can just type the commands
Ok done that
do I need winflash running at the same time?
