isnt it suppose to be in position 2 before you can change the bios?
you can run the winflash unlock commands from a command prompt in windows
Pyr0m@nI@]{;18083354 said:open a cmd window, navigate to the atiwinflash directory and type the commands
Watching very closely... with baited breath, fingers crossed etc... and toolkit to prise the credit card from the SWMBO's hands!![]()
ok, open the folder where you have atiwinflash, hold shift down and right-click in a blank areaI'm crap at stuff like that![]()
Pyr0m@nI@]{;18083384 said:ok, open the folder where you have atiwinflash, hold shift down and right-click in a blank area
you should see a menu item "Open command window here"
this will open a cmd window at that location and you can just type the commands
Ok done that
do I need winflash running at the same time?
