As for the chassis being the same as the DC2, maybe very loosely based on it, even our DC2 Integra Si is very different to the Type R, the ARB's would not fit with out modification.
Should have put it through the dishwasher first
i had an old 216GTi like that, but it was the block that had been warn away by all the crap in the water, the block was only about 1mm thick where it failed it had be shotblasted away that muchHead is now off, and clear to see where the gasket has failed. It's actually due to corrosion, which is a shock. It did have water as coolant when I bought it, so suppose it must have been like that for a while.
Stripped the head down to re-use the camshaft carrier and the pulleys, and will be finishing lapping the valves in and re-assembling the hybrid head tonight.
That would be my life over if i stuck an engine on the cooker!
i bought it for spares so it wasnt a problem to me
