*Updated after calibration*
Small amount of back light bleed around edges. The most at the bottom. I haven't taken the monitor apart yet to try and correct this.
Hi Vega,
I opened mine up to look at the backlight bleed. Very simple to do. I basically found that the bleed isnt coming around the edge . As it employs edge led lighting, the strength of the led around the edge is enough to shine brighter through the diffuser and screen.
So, I wondering what else I could do. I expected it to be a seal problem, alas no. It's almost like I would need to add an extra thin diffuser around the edge to supplement the existing one to block out the extra light which the current diffuser doesnt evenly pass out. (i.e bighter around the edges)
Have you had alook yet?
