Look like they are stupid going over 1.4V voltages and kill the chip. I don't like 32nm chip! Stick to 45nm (longer lifetime)
I was just thinking never had all this trouble with 920s
Nope! That one one is running at stock speed 3.6GHz.![]()
Prime stable at 1.37vcore 4.8ghz 48 x 100 ram at 1.5v CPUPLL 1.8v VCCIO and VCCSO auto
Isn't 1.4v or above dangerous in a 32nm chip?
That's pretty good. The cpu vcore @ 1.376v is spot on with Intel recommend and also your memory ram volt at 1.50V is spot on with cpu pll is spot on below 1.8v and finally your BCLK base is fine at 100MHz. That's pretty good 4.8GHz, what temperature is that dave ?
Couple of those dead chips are below 1.3v...
Quick update, bought another 2 x 2GB of the GeIL Value Plus 1600mhz so all 4 ram slots are populated (4 x 2GB total), no degradation, same clock speeds, same benchmark results (SuperPi and Cinebench 11.5)
Stock timings and volts as per the ram sticker 9-9-9-28 @ 1.6v
I have these running at 9-9-8-24 @ 1.45v
Get 'em while there cheap folks
http://www.overclockers.co.uk/showproduct.php?prodid=MY-104-GL&groupid=701&catid=8&subcat=1517
I wish you had said that last night. already ordered a 8GB corsair kit, £30 more than 4x2GB
Am amongst giants in a SuperPi test(DB006 7.706)
