OcUK Minecraft Server - Rules & Chat
Aww... the dwarven cavern has been built through my stairway to my diamond mine :(
(The huge hall!)
Just fell down my steps and nearly died! :p
Edit: Just gone down to my main mine and that's been took over aswell! :mad:
(The huge hall!)
yeah sorry pete, I did ask weeks ago, but you never seemed to be on/respond I was told by fur and others that you'd be fine with it though :o
Help yourself to any cobble/resources sticking out in the hall though mate. And I'll make sure you have a house in the city (in the nice part, not the slum I'm putting fur in :eek:) for compensation :D
Can we get the rules in 1 place, or if they have to be in 3 places - can they all be the same?
1 .http://forums.overclockers.co.uk/showpost.php?p=18134994&postcount=1
2. http://ocukmc.co.uk/?page_id=20
3. the signs in the 'noob room' at spawn.
Some rules are the same, but worded different/more additions to them.
The new 'mob spawner' rule doesn't appear in places 2 and 3.
Makes it very hard to have a rule system if they aren't the same everywhere.
Also any word on when these mods will be in place?
When someone tries to inform someone of a rule on the server, certain people like to shout "GRASS GRASS GRASS" or "keep your dirty nose out of it" etc. Kind of puts people off trying to help/inform.
I've tried to update the website rules to the latest ones but I would need Radyr to double check over them, I also had to re-word some of them due to linking to this thread or previous mods (/bbhere). So if Windle could read through them and update the OP that would be great also add any more if needed. As for spawn rules we will have to keep them short and sweet and just give the website link for full details as everyone playing on the server should really read the rules on the website or OP first.
The rules haven't be 100% confirmed since garsands left but the ones on the website generally cover the events over the past few weeks and the tweak of rule changes. Flymod and such has been a known no no since the previous world and generally would make sense not to use it considering we are playing a Survival multiplayer server.
(The huge hall!)
I shall also donate you some diamond for the disruption caused :D I did see through the floor yesterday day to loading chunk bugs and it seems like you have cleared out 95% of the mine any ways! :p
Don't worry guys. I needed some cobble but there's plenty available anyway. And i'm working on a new project anyway so that mine and house was soon to be obsolete :)
And yeah.. i'll gladly accept a decent plot of land and some diamond ;) :p
gotta turn this
into this
oh no windle that cavern was dug manually/carefull tnt mining (1 block in a 3 block deep hole ever 3 blocks)
on this pic
that room is the black box at the bottom.
and will be done i na more random way by the tnt being flung
to make a big natural looking hollow instead of a cuboid.
Gonna need a few weeks to get the tnt together and make the entrance hall first.
For scale on the thin vertical lines they're 2x2 corridors it's going to take a 64 stack of tnt to do 16 blocks long, and those corridors are in the 400 block range.
So 25 stacks of tnt for each thin red line, minimum.
Are we able to place junctions off the main tracks? As the south line goes past mine but both the main stations are a long way off. Would only have to do a 5 second hold and a switch to go to my sub station.
I don't have a problem with this. Put some obsidian in with a 'wait' sign to hold it in position, then give them the option to switch the track to your house by hitting a button hooked up to redstone. Don't forget you'll need to reset the track after though!
http://www.minecraftwiki.net/wiki/Minecart_Mania! should help.
shes up
2011-01-11 19:26:27 [SEVERE] Unexpected exception
java.lang.ArrayIndexOutOfBoundsException: -1
at ex.a(SourceFile:39)
at ex.c(SourceFile:101)
at fx.a(SourceFile:158)
at fx.a(SourceFile:120)
at fx.b(SourceFile:94)
at fx.a(SourceFile:64)
at fx.a(SourceFile:37)
at fx.a(SourceFile:22)
at ff.a(SourceFile:1644)
at hz.c(SourceFile:26)
at lc.G(lc.java:573)
at gu.G(SourceFile:24)
at lc.b_(lc.java:191)
at gu.b_(SourceFile:28)
at ff.a(SourceFile:1072)
at fm.a(SourceFile:37)
at ff.f(SourceFile:1048)
at ff.c(SourceFile:1027)
at net.minecraft.server.MinecraftServer.h(SourceFile:274)
at net.minecraft.server.MinecraftServer.run(SourceFile:216)
at cj.run(SourceFile:490)
