Thanks for the tip... Lovely post workout snack.
Stuffing them was difficult.
Haha, got some of those today as well. Ended up using them as a scoop for my tuna
^Did you even toast them beforehand? and isn't that horribly dry without any mayyonaise in it?
Hmm, can you tell I've not had pitta before? I hang my head in shame.
I'm going to be immature and put it out there, every time I see "TP", I think Toilet Paper![]()
I've got this one which looks similar to the on semi-pro posted. I regularly hang a 130kg barbell off it when doing calf raises, although to be fair the clip is beginning to buckle. Keep forgetting to get a beefier one!
Good Leg/Shoulder session today. My gym finally got a 2nd weights room so i can actually squat now (only one rack in the whole place before!)
Leg Extension 12,10,8,8,6 - 180,200,220,220,240 lbs
Leg Curl 12,10,8,8,6 - 90, 110, 120, 120, 130 lbs (weak hammys are weak)
Leg Press (Lever style not sled) 10,10,10,8,8 - 470, 490, 490, 505(max), 505 - Maxed this stack out a while ago, just trying for reps now.
Calf raise (toe press on leg press) - 3x10 - 440lbs
Squatz - Only my 2nd week so really trying to concentrate on form, not easy when I'm one of the only people to bother doing them and theres no mirrors in teh new room yet! Bar - 3x8 (Just to get a feel), 40kg 2x8, 60kg 2x8. Gonna stop here because I can notice my my quads getting more activation then they should, will sit at 50/60 until its bang on.
Seated Shoulder Press - 17.5kg DB's 3x8
Front Raises - 9kg DB's 3x8
Lat Raises 7kg DB's supersetted with upright rows 9kg DB's, my word this hurt! 3x8
Some shrugs to finish off up to 27.5kg DB's. Did one set of 30s just out of interest and my ROM was hampered so went back down. 3x8 exc 30s
Although my weight loss has stalled for 2 weeks, my lifts have pretty much all gone up so I'm happy for now.
I think its the hardest way to do em, and I always try to go the hardest route.
Leg Extension
Leg Curl
Leg Press
Calf raise
Squatz
Originally posted by: Morba
Why?
Hardest doesn't mean most effective or most efficient, let alone safe.
