I've just compared the BIOS from the MSI forum and this one and they are the same. Gonna go flash now.
Scotib could you tell us please if the voltages or fan speeds have been increased in this Overclock MSI 580 bios campared to the stock speed MSI 580 bios ??
Us mere mortals don't have PMs on OcUKAlso - does anyone here now how to send a PM to another user or to get their email address?
Cheers.
.shannowx which setting do you adjust in fermi editor?
is it the one that says max voltage table?
guys what are bench you using to test these overclocks ?
ive tried 3d mark11 basic
msi kombustor
both stable with 76c max temps
volatge 0.962-1.0v
add neallnufc to xfire if you wish
Think you have to flash them from a bootable USB stick..NVFlash doesn't seem to work either for me (under Win7 x64).
I get the info screens with Press Enter to Continue. After getting to the last one the application window just closes.
Am I missing something obvious or do I need another flash utility under Win7 x64?
Svet said:Create bootable USB key, guide:
http://www.bay-wolf.com/usbmemstick.htm
Once done remove/delete autoexec.bat and config.sys from your USB key root directory
[remove them both if they exist in your USB key]
Then get attached archive file and extract all files to the USB key. [See/check PM{Private Message} for archive password]
Then reboot the machine and boot from the USB key.
When you see A:\ or C:\, type:
nvflash.exe -b n580old.rom [ENTER]
Wait process to finish, then type:
nvflash.exe -4 -5 -6 KG3.ROM [ENTER]
Wait process to finish, then reboot the machine and recheck the VGA clocks.
Thanks for the swift replies. I've flashed dozens of mainboards but never a graphics card, least of all one costing £400
The 'BIOS FILE' linked to above extracts as NV801MS.KG3
I'm assuming I just need to rename it to KG3.ROM to get it to work with NVFlash?
I think the MSI rep should give us all copies of 3dMARK 11 for our troubles
what do you think ?![]()
Mine is stable at stock volt as well. I wouldn't mind a freebe in way of compensation.
