I think they're 9am-3pm
That is correct, also on their tracking system they should be able to give you a time of delivery.
Really helpful info there, thanks very much! It gives me a good idea of speeds I should be aiming for!
What would you regard as the maximum "safe" voltage? And am I right in thinking that every GTX470 has a different stock voltage, and it just depends on how much voltage is required for that particular chip to run at the stock speeds?
Just did a heaven benchmark and got a score of 898, with 36.8FPS average. High settings, normal tesselation and 4x AA at 1680x1050. CPU is a phenom 2 955 at stock and 4gb ram.
edit: also, the GPU didn't go any higher than around 62c, so it looks there's a good amount of room for overclocking.
My 470 is being delivered by normal delivery so should arrive on Monday, but do I get an option to select a delivery time? It's just nobody will be in our house until about 4 and I dont want to miss it![]()
