Who You asking ? and what do You want/need to know?
Everyone with a Asrock Extreme6, probably be good to compare settings.
Hi Elevon
The back bracket is made of metal and is very very close to a few of the soldered pikes on the rear of the motherboard....
This worryed me big time when i started fitting my 9900 cooler as i must have spend about 30 minutes checking there was enough clearance
But there is enough clearance between the back bracket and soldered pikes..![]()
Just a thought, what is core current limit in the bios?
I know it has something to do with voltage when turbo is applied but just wondering what you guys have it set to?
Mine is 150 at default, I have tried 200 but still windows would not load![]()
I have no issues running at 4.5ghz with 1.25v 100% stable
I have pushed the vcore up to the recommended max of 1.38v but it makes no difference, the board will post fine with the 46x multi, it just refuses to load windows even if I use the pre-set over clock I get the same results.
It's either the CPU has hit a hard wall or I am missing something?
One thing I dont understand is all this talk of "Turbo mode"... don't I just change the multi to overclock it? What is the difference between "Additional Turbo Voltage" and "CPU Core Voltage" ? And what difference does it make using Offset or Fixed Mode?
Is it LLC Level 1 that keeps the vcore the most stable?
If I were you I would forget everything you think you know about overclocking the SB cpu (not being sarcastic) and have a look at this link, it tells you everything you need to know to get started.
Once you have a good understanding of what the auther has written you should know enough to take your overclocking higher.
http://www.clunk.org.uk/forums/overclocking/39184-p67-sandy-bridge-overclocking-guide-beginners.html
You can choose to use one the bios own turbo profile settings from 4Ghz (x40) to 4.8Ghz (48x) or you can choose to just enter your own multipliers settings..This is my point - as far as I can tell the ASRock Extreme 4/6 is different to the other SB motherboards. No mention is made in the ASRock bios about Turbo Multipliers... this is what I am finding confusing. The disparity between what the MSI/Asus/Gigabyte guides/people are saying and what I am seeing in the OC Tweaker section of the bios.
Also it is very disappointing not to be able to use the windows software to overclock. It makes ASRock look like they can build great hardware but suck when it comes to software.
Do You actually have an Asrock board ? or are you just weighing them up ?
because if You have and installed the "asrock extreme tuner" you can change everything in windows, voltages,Multipliers, fans etc
Yes I do, do you? If you did you'd know the windows software is barely functional. You can change volts on the fly and fans. But if you change multi you have to reboot. As far as I am aware the other manufacturers manage to have this feature working just fine.
I discovered last night the PLL over voltage option does make a difference. I disabled it and not even the pre -configured 4.8ghz could get into windows
I discovered last night the PLL over voltage option does make a difference. I disabled it and not even the pre -configured 4.8ghz could get into windows.
With it enabled and about 1.52v I can get a two hour stable 5ghz prime running. Little toasty though at about 80c. I am going to try to reseat my waterblock. The reason I went for the asrock was for the pci slots and the lga775 mounting holes to use my existing water setup.
Hi JBod, I think you will find that any windows based tuning software will require a reboot when changing the multiplyer. They are all a bit if a gimmick, best to stick to the bios, or now (UEFI) you have far more control in there, as I'm sure you know.
Your temps do look high, which board do you have Extreme6 or 4?
I have tested mine @ 5+Ghz and never went above 68c with a cosair H70.
Which bios are you using as you mentioned a Vcore of 1.52v?
That would suggest that you are not using the beta bios which allows for higher overclocking, cpu allowing obviously.
You are a strange one ! go back and read Your posts... they came across as real lazy Newbie questions !
At over 1.5v and 80c You are well out of what would be My comfort zone
I got to 5.1ghz @ 1.416 volts into windows an ran super pi 7.563 and winrar bench 4235
As I said before CPU internal PLL was off as I found it to do nothing, interesting You found otherwise.
I have only primed at 4.4 and 4.6 but it was a waste of time for me at for some reason winXP 32bit seems unstable compared to X64 and although it primed ok a Crysis bench crashed it, thinking this a memory related issue was when I discovered the Memtest uncovers any weaknesses.
Because basically we are overclocking "correctly" with Multipliers and lack the full control of low to high power phases we need to compromise so the Cpu does not fall over at some Mid multi/voltage load...that's My analysis anyway
I did notice in Prime the Multi was stepping up and down, I'm sure the Turbo power setting in the bios would stop that if required.
Hi JBod, I think you will find that any windows based tuning software will require a reboot when changing the multiplyer...
