The Left Handed Build
OP
6 Sep 2010
Sunny Mumbles
You seriously need a case mate... That just looks like a tragedy in the making lol
Even if you rig up some sort of test bench so it's all open-plan but actually fixed onto something...
I thought about setting up a test bench. But with my trapped nerve & Mrs Piggins foot, I just have not had the time.
As for the tragedy, everyone is banded from the room this is kept in :)
When is the case arriving?! :)
But those 580's look nice :)
kd
The case is making good progress @ the moment.
There is an actual design now, with CAD drawings.
So progress should be swift. :D
OP
6 Sep 2010
Sunny Mumbles
The 'deliberate mistake' looks like a small amount of EXTRA thermal padding just to the top right of the RAM chips. I don't think that was padded on the stock cooler
You are correct about there not being any thermal pad being in this area on the original but on the EK diagram there is.
Is this a quiz? If so I think it's the lack of thermal pads somewhere - either the fiddly small ones on the mosfets or the rather more obviously naked R125 chips.
Spot on M8, left the pads off the R125 chips.
I got so excited when doing the block, I forgot to put them on (even thought to my self how generous EK have become with the quantities they ship in the packs) :rolleyes:
Luckily, when I was doing the second card I spotted the mistake & put the pads on.
This could have been a costly error :(
OP
6 Sep 2010
Sunny Mumbles
Even thought I have been incapacitated with my bad arm, it has not stopped me spending money.
The boxes keep on rolling in. (much to the displeasure of Mrs Piggin)
I see something shiny
Individually rapping is not what its cracked up to be :rolleyes:
A quick group shot
Thought I would give EK compression fittings a go this time.
Very good quality
I don't know if I will go with white pipe again but thought I would try it out.
16 Nov 2010
Swimming in a lake
I'm sure you can make this up to Mrs. Piggin! Still hardly costs as much as a couple of pairs of shoes! Also I'm sure you'll get more use out of the PC then shoes! In fact she'll probably get more use out of the PC than shoes! :D
That's some nice shiny bits though :)
kd
OP
6 Sep 2010
Sunny Mumbles
kd
Thanks kd,
The problem is Mrs Piggin uses the PC more than me @ the moment.
I hardly get a look in, as she is searching the internet for 'cheap' shoes :rolleyes:
Lord only knows what is being delivered these days when I am in work.
10 Nov 2010
West London
lol, no m8.
She tells me, she paid for the left & they chucked the right in for free. :rolleyes:
lol.
I do like the look of your EK compression fittings. I have been very impressed with the quality of all EK's stuff so far. I don't know about you, but I find compression fittings are really handy if you keep changing your loop as I seem to.
I have also found that having a few 90 and 45 deg fittings helps, especially in cramped areas. However as you are designing the case perhaps you can avoid such issues [Of course there's plenty of room for large loops on the shelf version of your computer :) ].
OP
6 Sep 2010
Sunny Mumbles
lol.
I also think the EK fittings, they look pretty & the quality is excellent ;)
The quality seems to have improved since they changed to the new packaging.
As for using compression fittings, this is my first experience with them & I am very happy. (fingers crossed, no leaks yet)
As for 90 & 45 degree bends, even they exist on 'the shelf' lol.
I will be using these fittings again in the build, as I find they make the tubing runs very neat + adds to the bling factor :D
10 Nov 2010
West London
Bling! Careful what you say in front of Mrs. P - she might get the idea you are going to give her something shiny and I am not talking about compression fittings!
OP
6 Sep 2010
Sunny Mumbles
I decided with all my new equipment, I would have to get a larger power supply
I managed to get this from a very nice man on Overclockers MM
A quick look in the box
More cables than I will ever need (hopefully)
Finally the PSU, an Enermax Revolution 1250
I decided that this build will be special & deserved braided cables. :)
Old braid stripped off
PSU opened up
Lots of dust inside :(
The cables were braided with something special. :cool:
This time it was dense weave 'ribbon' cable (silver/white ribbon with black braid) specially ordered in by (name removed)
Cables braided & looking good :)
Unit finished & ready to be fitted.
10 Nov 2010
West London
Is that PSU a semi-modular one?
What was your reasoning behind choosing this particular PSU rather than, say, a fully modular one that would have avoided the need to open the PSU to do the braiding?
