Posts over at the techpowerup forum suggest that running the 6970 Bios can kill the 6950s as the new bios can fry the memory due to voltage increase. Any truth in this? I'm tempted just to reflash my card to enable the extra shaders only
Posts over at the techpowerup forum suggest that running the 6970 Bios can kill the 6950s as the new bios can fry the memory due to voltage increase. Any truth in this? I'm tempted just to reflash my card to enable the extra shaders only![]()
Afterburner does yes. I use Sapphire Trixx for my overclock of 900/1375 and RBE to change the voltage. Powerplay still works perfect and drops back to 250/150 for 2d. I also found it much easier to set a custom fan curve in Trixx as well. I agree though, CCC should enable unofficial overclocking as it would be much easier!
In response to this in another thread;
Ensure your BIOS switch is in position 1 before anything else.
Avoid the 6970 Bios. What you want to do is modify your own BIOS to unlock the extra shaders.
First you'll need GPU-Z and this: http://www.techpowerup.com/wizzard/Mod_BIOS_HD_6950.zip
First you need to dump your BIOS in GPU-Z - there is a little icon next to the bios version, click this to save your bios.
Extract the 'Mod_BIOS_HD_6950.zip', put your bios in that folder and rename it to 'original.bin'. Run the run.bat, follow the instructions and you will end up with another file called 'modded.bin'.
Now download an extract this: http://uk2-dl.techpowerup.com/Tweaking/HD_6950_to_HD_6970_mod.zip
Ignore all the bat files, all you want is winflash. So copy the winflash directory somewhere easy, I'll use c:\ as an example. Also place the 'modded.bin' you generated in the previous step in the winflash directory.
Now open up command prompt as administrator, and type 'cd \winflash'.
Now you want to do;
atiwinflash -unlockrom 0
atiwinflash -f -p 0 modded.bin
Follow any instructions and reboot when it's done.
Once complete you should have 1536 shaders (you can check this in GPU-Z).
Just note that you do all this entirely at your own risk. That said, if you run in to problems, you should be able to just flick the switch back to position 2, and you're all good.
I deleted the .zip I had of that Laney, otherwise I'd upload it for you
ONLY Unlocking the shaders seems the best way of keeping your card safe for now. I've set my clocks via afterburner (with unofficial clocking enabled) to 6970 clocks with no voltage adjustment and will be testing stabilty over the next few days.
If you get Afterburner 2.1.0 then PowerPlay is not disabled when Unofficial Overclocking is enabled.
Ok today I've read this whole threadand now I'm ready to give it a go!
However I was planning to follow this method below but "Now download an extract this: http://uk2-dl.techpowerup.com/Tweaking/HD_6950_to_HD_6970_mod.zip" link isnt workingso where can I get this from?
[timko];18629409 said:They've moved it to their official download section right here...
http://www.techpowerup.com/downloads/1920/HD_6950_to_HD_6970_Flashing_Tools.html
It's linked to on their guide just above the "Testing" section...
http://www.techpowerup.com/articles/overclocking/vidcard/159
Is there any point now to flash again with my own BIOS modified (My card is ASUS anyway so I guess exactly the same BIOS) how I was originally going to do? If not what's next just overclock to 6970 clocks and I'm done? Seems too easy![]()
Just double checked mine, didn't take notice of the settings in Afterburner.Ezyryder said:If you get Afterburner 2.1.0 then PowerPlay is not disabled when Unofficial Overclocking is enabled.
Anybody here running 2 6950's unlocked?
