So come 22nd March we should have a new, worlds fastest Dual GPU card.
Who of us on here is seriously thinking of getting one ?
What are the conditions that will secure a definite purchase ?
Cheaper than 2 single cards, cooler and quieter than 2 single cards, overclock exactly as well as 2 cards................
Actually if it just averaged out to offer as good value as 2x570gtx it would be a great buy.
I can take a little more heat and noise but to compensate you want to save money.
THe 4870x2 I had was louder and way hotter, overclocked less well but was FAR cheaper than 2 cards, the 5970 was too expensive to be worth dealing with those issues, as is the 6990 and most likely the 590gtx aswell.
Unless you're going to drop £1400 or so on 2x590gtx/6990's for quadfire/sli, then theres no reason to get a dual card.
Will be impressed if they manage to get it quieter/cooler/as fast compared to the single gpu's.
Its hard to get a read on just how bad the noise is on a 6990, [H] showed better temps and didn't find the noise insane while Anand seem to think its insanely loud and awful, too hot and their power testing is beyond ridiculous.
THen again Anand are a little Nvidia biased and [H] a little AMD loving of late.
