It would seem unlikely.
So then how does he run on 1 set of softs for like half the race while others struggled. It's his maiden GP too.
maybe the car is just setup/built in a manner that is designed specifically in a way that helps conserve tyres, with kamui 2 stopping because he is probably the more mental of the 2. Guess we'll see next race when they run a legal rear wing.
Kobayashi would have had the same benefit then if the wings were to "blame". I think it was just a bit of luck of Perez' part and due to the unknown factor of the new tyres.So then how does he run on 1 set of softs for like half the race while others struggled. It's his maiden GP too.
Because the rules are there for the driver in question who lost a place - not in regards to being in conjunction with team orders and the other driver gaining a place as wellHow has the spirit of the rules been demolished by Ferarri?.
Button should have yielded the place back straight away.
Button himself said Massa was out of position, so is it unreasonable to think that Alonso genuinely passed him? How many times have we seen someone defending position, only for them to make a silly mistake and the guy following the squabble also passes at or around the same time..
Did the Sauber rear wing which was later disqualified allow their tyres to be run for a longer distance compared to the other teams or was Perez actually that good that he could climb the field and still use only 2 sets.
So whats everyones general concensus of the race?
Exciting?
I just watched some of the highlights this morning and have to say.. wasn't really blown away. Just seems to be faster cars stuck behind slower cars (Massa v Button was a fine example) and overtaking a myth.
Perez only stopped the once. Which, given the wear rate of the Pirellis in testing, is quite a surprise.I think both McLarens had only two tyre stops - and maybe other teams did also - so its not particularly notable that Sauber were able to go for 2 stops for each car ( would it be possible to design a car around a basic premis of low tyre wear? For a mid grid team like Sauber it could be a way to go). Really unfortunate they got DSQ'd from well deserved points
They say that the new pairing doesn't give enough information for viewers that know less about F1, to that I say those people could always use the CBBC feed, or 5live.
I read an article on PF1's site their "winners and loosers" of the GP and they have a good old go at DC&Brundles commentary, and I have to say I totally disagree with what they said. I found the commentary to be far far better than Leggards babbling, with few mistakes made and even less stupid questions. They say that the new pairing doesn't give enough information for viewers that know less about F1, to that I say those people could always use the CBBC feed, or 5live.
"We tested it, we ran the system earlier in the weekend and we decided that there was a potential, albeit small chance, of a reliability issue with it so we elected not to run it this weekend," he explained. "But obviously we didn't want to tell the world – although looking at the start the guys had, it looked like we didn't need it."
Horner said he was also amused by the speculation that had run around the paddock suggesting his team had a lightweight start-only KERS system.
"You guys [the media] went off on a great little tangent, but the problem is that you have probably made Adrian [Newey] think of that one now! I can blame you lot for that then."
It's definately possible to design a car to be easy on it's tyres, however to concentrate on that alone would compromise other areas of the cars development which would end up being a major detriment to overall laptime which would negate any benefit of reduced pitstops.
Horner on KERS (from autosport)
Its been known for a while that the Renault is a decent car (and how dreadful Heidfeld is lol), so Im not that surprised that Perez did the race in one stop
Petrov races for Renault, not Perez, mate![]()
