Hazro series - HZ30Wi, HZ30WiQ, HZ27WA, HZ27WB & HZ27WC
Managers Post:
We are closely monitoring feedback so please share your experiences [both +VE and -VE] as feedback from customers is vital for future improvements.
Most of the 'spots' or 'dots' noticed are not defective pixels: its dust that has gathered behind the glass. Clean room operations minimizes build up but total elimination is impossible. Dust gathers on all panels but the combination of panel vibrancy and glare can make it more noticeable on these models [as well as closer customer scrutiny].
Dust accumulation was always a problem from the moment this monitor was conceived. We tried open front bezels but contrasts seemed washed and faded. Color tinging wasn't so much of a problem so a transparent filter would have sufficed. That was until we tried applying it - very difficult and time consuming. Glass was the only option. We had to choose glass which didn't compromise the viewing angles so we stuck with Asahi from Japan.
Encapsulating glass around an open beaded trim was another problem: this is evident from posts which comment on how the glass seems 'raised' in some corners. Glass uniformity across the horizontal plane [in theory] has a tolerance of +/- 1mm and human assembly adds another +/- 1mm. Adhesive which bonds the glass adds a final +/- 1mm.
Until now, we didn't have a 'general everyday use' monitor as most of our displays were industry orientated. A few consumer grade monitors we did have were snapped up by OEMs looking for '1 vendor only' licensing. We still have budget displays floating about in EMEA distribution channels under retailer specific brands. As a B2B company, launching these models into the consumer domain was always going to be a challenge but we're confident we can overcome any shortfalls to make a success of it. We feel for the price, the combination of aesthetics, resolution and panel quality cannot be matched.
We welcome your posts and look forward to hearing feedback.
Thanks for the great post.
I'd be interested in knowing what the end point of keeping this monitor in a moderately dusty room would be...especially with dust specs appearing this early on. I'm guessing there's no way for the customer to remove the glass panel and clean it?
Thankfully I don't think I suffer from the dust problem but I do have some dead black pixels on the bottom far left hand side and a couple on the far right.
I can live with some dead pixels as long as it doesn't get worse over time.
You can't even notice them unless you're really looking for them and are very close up to the screen or have a plain color background displayed.
There is little chance of dust entering the cavity infront of the panel and behind the glass as its bonded around all 4 edges. Saying that, we've seen insects crawling INSIDE panels which are sealed so we wouldn't rule it out.
The pixel I'll leave it's this circled thing that is annoying me, even after cleaning, still there.
I've received my HZ27WC today and I can say I have NO DEAD PIXELS!
I have a tip for anyone with what looks like a small blob as in the picture silverf0x has posted above as mine did have one in about the same place and roughly the same size (wish I had taken picture before of mine).
With your finger nail gently flick on the glass screen where the blob is and see if it will move first. If it moves you now know this is a dust problem and you can achieve a perfect screen. (finger crossed!)
To get my screen perfect I needed about 10 flicks to eventually get the piece of dust to maneuver down the screen and completely out of sight below the black casing.
I will also add to get the best from this monitor you should invest in a calibrator (I have a Xrite i1 Display 2). The colours now look identical to my 27" iMac.
I'm now really happy with my Hazro.
Tried flicking but it looks like mines is on the actual screen and not the glass. It's very annoying now and although quite small very noticeable on pretty much 90% of things I use my screen for.
I have just tested mine for dead pixels. I have what looks like a small cluster of dead ones on the middle left hand side, pretty much just like silverfox's, and a single dead pixel bottom middle.
On a white background i also have either quite a few single dead pixels or the dust issue. I'm inclined to think these extra sposts are dust as they seem too fine. Once i sit back from 30cm, i can't see the dust ones at all, while the real dead pixels are noticable.
I'm still trying to figure out what to do now. The glossy coating is a little annoying to me, and dead pixels really bug me. But the Dell has higher input lag (nooo) and LG frost coating, oh, and costs tons more. I'm inclined to just gouge out my left eye so i can't see the dead pixel anymore.
Also, on the green test background I have the yellow tinge going right around the edges of the entire screen but so far in day to day life it's not at all visable.
So the other day I was excited about the three extra free toppings on my pizza Margherita. Well, soon after and to my utter surprise, the waiter comes over and without asking grinds black pepper onto my pizza, prompting me to exclaim: "I don't want pepper!" But the waiter was rather indifferent: "Sorry sir, with all free toppings comes black pepper... and you can't return it." Aghast and struggling with acceptance of the situation, I replied: "And now, how do I get the pepper off!?"
Perhaps Apple knew something about inner-glass-dust when they made their 27-inch Cinema Display glazing removable; and therefore user cleanable.
A tiny piece of felt inside the glass with a magnet behind it and another felt-lined magnet with a handle of sorts to hold and drag on the outside to wipe dust on the inside? :rolleyes:
Perhaps hazro can tell us how they would remove the glass when monitors come in for repairs?
Suddenly, to great distress of my budget, the Dell U2711 and Apple Cinema Display enter my radar again.
Wait for the Samsung SA850? Unless Samsung releases it within the next 2 weeks, I can't really wait. After ordering there's still the 1 to 2 week shipping delay to where I am located. I have a system to build, work to be done, and a client waiting.
I'm quite terrified right now. Hope mine will be fine when it arrives today/tomorrow. Mine also has been shipped from UK to NL so I hope that process hasn't added to destructing the screen in any way...
I can also see people returning their screen because of dead pixels and Hazro saying "No we won't accept as this is 'dust' and not a dead pixel"
I am sending mine back. When I pay my hard earned money for something I expect it to be without faults or imperfections. Guess I will go for the DELL or the Samsung
Shame because otherwise the screen looks nice and colours are great
Perhaps the longer duration of transit vibration causes dust to drop off and settle down below... I'm just trying to find something positive on your behalf.
meh mine comes today and I'm at work, I'm not going to worry though, if not happy it will just go back within the 7 day return.
of course I want this monitor to be great but from the posts its looking more and more like I will have the same issues.
I was on the cusp of buying a HZ27WC but I wanted to see them in stock and then the "launch" price creep held me back and now they are sold out.
I can give some feedback on my experience with an NEC 20WGX2 Pro in relation to DUST. Hazbro has a clear policy on PIXELS.
The 20WGX2 Pro an S-IPS glossy screen 20" monitor which I purchased in 2006. It has definitely acquired a few flecks of dust behind the glass over the years. There are enough now for me to notice them especially because there is a scattering of them near the bottom left corner hence why I am looking to replace.
I think because it is a glossy glass screen any dust behind or on top of the screen is really accented. I got used to dust on top of the screen and just use a puffer every so often to blow it away.
If I had a new HZ27WC, I would make the decision regarding DUST based on if I noticed it in normal day to day work use. I mean if there is a fleck of dust behind the glass which you have squint to see... you are going to have 10 flecks of dust on the top of the glass to clean off no matter how clean your environment is.
My advice is if you don't notice dust and dead pixels at normal viewing distance, you have a great monitor at less than 50% of the price of the Apple and without the matt coating of the Dell (which masks the problems to an an extent anyway).
It would be really interesting to know what percentage of these monitors have pixel/dust problems vs. perfect.
I've just ordered the HZ27WA, but the number of complaints here about screen quality are worrying. Will post my findings when it turns up tomorrow, but would appreciate hearing from anyone else who has bought the "A" model.
After looking at my screen again this morning I hate to say it but I have noticed some more dust particles on my screen albeit small but they are there. Can't say I am really happy anymore. I think I must have been to tired last night to notice the others. This is such a shame as I think the monitor is really nice but I can't live with imperfections. Once I know there is something on the screen my eyes are just drawn to it. If only you could remove the glass panel (like my 27" iMac) I am sure I would be able to achieve the perfect screen and save all the hassle of sending it back etc. What is more annoying is my iMac looking at me and it's imperfection free!
Unfortunately I have no option but to return it under the Distance Selling Regulations Act.
mine was the 'A' model, dust and stuck pixels :(
I got dust + dead pixels
Thought I should register to add my voice.
I also purchased the 27WC model. I received it yesterday and ran the dead pixel test. I have a few dead pixels, but more noticeably there does seem to be a fair amount of dust.
The monitor overall has excellant picture quality.
But when the display shows mainly white (documents/software development) you can notice the 'spots'.
During game playing/browsing these are not noticeable.
I would say there is about at least a dozen either dead pixels/sub pixels/dust particles.
The big question, would I buy it again knowing the faults now? Probably not. Yep £420 was exceptional value but I would probably have thought twice and paid £650-£700 for the Dell knowing it would have no pixel issues.
no guarantee of course that a Dell U2711 would be pixel perfect, or that you wouldnt come across some of the 'tinting' and uniformity issues reported on that model. have to find a perfect screen sadly :(
even if Dell won't warrant it, you could buy from *cough, cough* and pay extra for a no-dead-pixel-test).
Just as an aside, there's really no reason to pay extra for a dead-pixel test when you have the Distance Selling Regulations - at worst the return shipping costs should be considerably less than the £25 charged by "that place you mentioned", and you also get to check the product for any other "features" you're not happy with. :)
