Still need a few tweaks for ccc panel,getting better FPS but game is very jaggy and not up to standard for me graphic wise.![]()
yea you need to force some real AA somehow the ingame AA misses loads of stuff, on my nvidia rig the game looks so much better forcing AA with a nvidia inspector profile..
maybe try renaming the exe to "shift.exe" aswell any performance enhancements in your drivers should help shift 2 aswell seeing as the engine is pretty much the same
jut bought teh huayra thing now im seriously poor!
it takes up more tyhan full screen i posted the AA settings i used in it a few pages back anyway, if you get tyhe dodgy white patch on the side of the screen alt+tab to desktop and back and it should be gone.
<?xml version="1.0" ?>
<Reflection>
<class name="BRTTIRefCount" base="root class" />
<class name="BPersistent" base="BRTTIRefCount">
<prop name="Name" type="String" />
</class>
<class name="GraphicConfigData" base="BPersistent">
<prop name="Mode" type="Fct" />
<prop name="Vsync" type="Fct" />
<prop name="AntiAlias" type="Fct" />
<prop name="Windowed" type="Fct" />
<prop name="TextureFilter" type="Fct" />
<prop name="TextureResolution" type="Fct" />
<prop name="Brightness" type="Fct" />
<prop name="CarDetailLevel" type="Fct" />
<prop name="TrackDetailLevel" type="Fct" />
<prop name="ShadowDetailLevel" type="Fct" />
<prop name="MotionblurLevel" type="Fct" />
<prop name="EffectsDetailLevel" type="Fct" />
<prop name="EnvmapDetailLevel" type="Fct" />
</class>
<data class="GraphicConfigData" id="0xEA8080">
<prop name="Name" data="Arknor" />
<prop name="Mode" adapter="0" width="1920" height="1080" antialias="0" refresh="60" />
<prop name="Vsync" vsync="1" />
<prop name="AntiAlias" antialias="0" />
<prop name="Windowed" windowed="0" />
<prop name="TextureFilter" texturefilter="5" />
<prop name="TextureResolution" textureresolution="5" />
<prop name="Brightness" brightness="10" />
<prop name="CarDetailLevel" cardetaillevel="5" />
<prop name="TrackDetailLevel" trackdetaillevel="5" />
<prop name="ShadowDetailLevel" shadowdetaillevel="3" />
<prop name="MotionblurLevel" motionblurLevel="0" />
<prop name="EffectsDetailLevel" effectsdetaillevel="5" />
<prop name="EnvmapDetailLevel" envmapdetaillevel="5" />
</data>
</Reflection>
make sure you clicked the "add application to current profile buton" and find shift2u.exe or it wont do anything
did you disable ingame aa aswell? heres my games config which you find in your documents
(some are set to 5 even though its aparently higher than the game does to)Code:<?xml version="1.0" ?> <Reflection> <class name="BRTTIRefCount" base="root class" /> <class name="BPersistent" base="BRTTIRefCount"> <prop name="Name" type="String" /> </class> <class name="GraphicConfigData" base="BPersistent"> <prop name="Mode" type="Fct" /> <prop name="Vsync" type="Fct" /> <prop name="AntiAlias" type="Fct" /> <prop name="Windowed" type="Fct" /> <prop name="TextureFilter" type="Fct" /> <prop name="TextureResolution" type="Fct" /> <prop name="Brightness" type="Fct" /> <prop name="CarDetailLevel" type="Fct" /> <prop name="TrackDetailLevel" type="Fct" /> <prop name="ShadowDetailLevel" type="Fct" /> <prop name="MotionblurLevel" type="Fct" /> <prop name="EffectsDetailLevel" type="Fct" /> <prop name="EnvmapDetailLevel" type="Fct" /> </class> <data class="GraphicConfigData" id="0xEA8080"> <prop name="Name" data="Arknor" /> <prop name="Mode" adapter="0" width="1920" height="1080" antialias="0" refresh="60" /> <prop name="Vsync" vsync="1" /> <prop name="AntiAlias" antialias="0" /> <prop name="Windowed" windowed="0" /> <prop name="TextureFilter" texturefilter="5" /> <prop name="TextureResolution" textureresolution="5" /> <prop name="Brightness" brightness="10" /> <prop name="CarDetailLevel" cardetaillevel="5" /> <prop name="TrackDetailLevel" trackdetaillevel="5" /> <prop name="ShadowDetailLevel" shadowdetaillevel="3" /> <prop name="MotionblurLevel" motionblurLevel="0" /> <prop name="EffectsDetailLevel" effectsdetaillevel="5" /> <prop name="EnvmapDetailLevel" envmapdetaillevel="5" /> </data> </Reflection>
Uploaded with ImageShack.us
you can see how my game actually looks in the high res screenshot thread btw, maybe yours already looks like mine?
maybe its because you dont have the advanced settings showing in your nvidia drivers control panel?
under 3D image> adjust image settings with preview > select use the advanced 3d image settings and click apply and see if that makes nvidia inspector show the options the same as mine
heres my shift2 nvidia inspector profile
try to import it?
http://snoop1050.pwp.blueyonder.co.uk/shift2.nip
<prop name="TextureResolution" textureresolution="4" />
<prop name="CarDetailLevel" cardetaillevel="4" />
<prop name="TrackDetailLevel" trackdetaillevel="4" />
<prop name="ShadowDetailLevel" shadowdetaillevel="4" />
<prop name="EffectsDetailLevel" effectsdetaillevel="4" />
<prop name="EnvmapDetailLevel" envmapdetaillevel="3" />
Having to play on medium graphics 'cos I think my GPU is a bit too sloppy for it
Would like to see a patch soon just to try and fix the few niggles I've seen so far, though.
