The H61 chipset doesn't support SATA 3.0 so a waste of time if you want to use the new SSDs . Better be a whole lot cheaper for me to worry about it.
Argh. Looking for any ITX board out there, B3 chipset revision, with H67 or P67 chipset. There's none in stock, OCUK doesn't even carry them. Any ETA from OCUK? Any other places where we can buy them?
I have ordered a Gigabyte GA-H67N-USB3-B3 and some Corsair Vengeance RAM. Once I get it does anyone want a small review(or at last some pictures) of the motherboard??
Only 4 SATA ports
I have a Foxconn which needs to be returned for a refund from another shop but there's nothing to replace it with Anyone know how long you have to return these boards?
I know the foxconn only has 3 ports but that was just a stop gap board and the Gigabyte one is a little expensive for a stop gap me thinks, however looks like I don't have a choice with time going so fast and not much progress with new boards, I need to get the refund for the foxconn.
Let us know how you get on with that underclocking on the board matey.
I'm looking at downclocking a 2500k for a mate in a build,but I wont pull the trigger on the order until I can find a board that allows voltage adjustment and lower multi's that are usable.
Not looking for an "S" chip,he wants his own custom clock speed.
Lower multi's and voltages on non k chips "should" work.
But I dont have any lying around that I can test.
Now I know there's a mitx H67 board I can reccomend,it's just a matter of time before another mate wants one.
