They're for DH wheels, overkill and too heavy for your bike.On a related note, my lbs has some mavic EX823 rims with the spoke cups and are willing to let me have them for 50 each, but probably overkill for my HT.
40 miles of that 80 was on dirt/singletrackSo, can you ride that out mountain biking, or just on the road. Only asking as you have TT bars on.
How long did 81 mile take you?
You only really need the V2's on a bike used purely for DH imo,
hm .. why do i have a 150 mm fork, if i am limiting its travel by setting the sag to exactly 30%? maybe someone needs 20-25%, maybe another one needs 40%. why is this so?
i adjust both, fork and shock, this way:
(fork) negativ chamber empty, comp and rebound full opened and positiv chamber 25% sag at the beginning. my fork has 150 mm of travel. ok. i need 90% (135 mm) of the travel for trailriding and the last 10% for bigger hits. so i roll slow on a descending road (how steep, is irrelevant) and try to compress (no bunnyhop!) the fork very hard with all my bodyweight (standing on the bike in downhill position = not over the handlebar, but centered over the bottom bracket, well, just like i ride the bike on a downhill). then i take a ruler and measure if the rubber ring has done it to about 90% (135 mm). if so - perfect!
if it's under 90%, i decrease the pressure about 5 psi and try it again until i reach the 90% of travel.
if it's over 90%, i increase the pressure about 5 psi and try it again until i reach the 90% of travel.
how much psi in the negative chamber? it depends on, if you like your fork softer or firmer. softer: lean your bike against a wall. pump up the negative chamber, until the fork begins to compress by itself to a maximum of 1 mm. firmer: decrease the negative pressure about 5 psi stepwise, until you think it's good for you.
rebound: at the beginning better slower than faster. and i don't middle out things 50/50. i rather devide in three thirds. so every time at the beginning, i set the rebound between 2/3 and 3/3. you have 10 klicks? set it to 3-4 from turtle. you have 15 klicks? set it to 5 klicks from turtle. 20 klicks? 6-7 from turtle ...
now i leave the descending street or the parking lot and try out the fork on the trail. at first the fast sections. the rubber ring is less then 90% up on the fast trail, i decrease pressure by 5 psi, until i have a usage of 90%.
then i move to the hardest sections and try to find out, if the remaining 10% have enough progression for not bottoming out the fork. if (not) ... then ... (and do not forget to adjust the negative chamber to the new positive setting at the end!)
if you ride your bike hard it could really be, that you will have less sag as you have assumed (and vice versa).
Booyaka ive got the same issue with my '10 Rev Dual Airs, ive never got the PSI thing down either, if i run lower pressures to get the Sag, the first hard hit they bottom out, so pump them up by 20 psi and i lose all small bump response, making them rock solid on the small and rough stuff. So im also very interested in knowing how and what, im about 150lb geared up 11stone.
glad i'm not the only one!!
I'm a bit "bigger" - about 15 stone. 130psi is recommended for me but even with full open compression i get almost zero sag and even jumping/pumping the bike up and down get barely 30% movement.
Thats exactly how mine behave, And the massive kicker, people say Set the sag with only + in, well you do this and i get the correct sag at 30 Psi, which is just bloody stupid and by far not the correct way of setting these Rev's up, plus with just + they have no - to create any spring type of reaction.
changing in 5 psi amounts does nothing either, as you probably lose that 5psi when you disconnect the pump lol.
hmm -ok - been doing some more reading and quick testing. With 90 PSI in both +/- chambers I get the requisite 20% sag or so as a starting point. I've set the rebound for now about 7 clicks from the rabbit (which is about 1/3 of the way thru the dial).
But I am still struggling to get much more than about 100mm of travel even pumping the bike up and down fairly hard - albeit stationary and not out on the "trail". Any less PSI and the sag starts increase but I do start to get more travel, but the sag at the start is about 40mm of the 150mm available which I think is to much.
get a decent pump !
but the problems you two are discussing ive had with every pair of air forks ive ever owned
only time i ever remember getting some to feel how i wanted was messing with thicker oils and shim stacks
You wont be loosing pressure when you disconnect the pump, unless there is something wrong with the valve on the forks, you will however drop the pressure slightly when you reconnect the pump.
That's why you need to ride and see how much travel you've used after riding. Set your sag, then ride to see if you're getting full travel after doing a decent ride with drops, rock gardens etc. Bouncing up and down while stationary will do fa.But I am still struggling to get much more than about 100mm of travel even pumping the bike up and down fairly hard - albeit stationary and not out on the "trail".
Sag should normally be about 25% of travel, so you should be getting 38mm on your 150mm travel fork.
