Does anyone have the power consumption and heat of this drive when at load?
	Can someone please help...
I have a ASUS Rampage III Extreme and after reading this thread it looks like I have the rubbish Marvel Controller. I take it I am going to need a PCI-E card, any recommendations? My Vertex 3 is coming on Monday...
This question has been asked three time in this thread, but no answers as of yet.
Hutchy said:
I've been searching the web and I can't find a single review where they actually push the controller cards to the limit (they push it to about 250-350MB). Currently looking at the ASUS U3S6, it's also quite difficult to find out out what chips the controller cards actually use.
Having been busy lately I completely forgot to research into the controllers on this motherboard, for some reason I thought it was an Intel one!
EDIT: The ASUS uses Marvell, damn it.
total speed isnt the only reason to buy this drive, read up on everything else it has! 60k iops for a start, hardware encription and compression too. brilliant! mine is due monday![]()
.Can someone please help...
Don't know if this will help....
http://www.intel.com/products/server/raid-controllers/RS2WC080/RS2WC080-overview.htm
.total speed isnt the only reason to buy this drive, read up on everything else it has! 60k iops for a start, hardware encription and compression too. brilliant! mine is due monday![]()
Thanks, but have you seen the price? 200-300 for a controller card isn't what I had in mind, the SSD itself only cost 220 lol.
I may just stick with the on-board Marvell. I'm definitely not buying a new motherboard and all of the controller cards seem to use the Marvell chipset. So until someone releases an Intel powered controller card or a card that can reach 6 Gb/s properly, I will just stick with what I have. It's not as if the speeds are "bad" they just aren't as good as I hoped they would be.
Coming from a WD 640GB HDD with a top speed of 110MB/Sec, any SSD will be nice.
Under normal usage the life expectancy is much longer than you're likely to want to keep it. Go for it.
