Can I ask...what is poached chicken like? I've never had it! To be honest I didn't know it existed =/
I strongly dislike it!
Chicken can be roasted, fried, grilled or turned into soup. I do not enjoy chicken out of a microwave or just boiled/poached. Bland rubbery junk I say.
Only had it once and it was boring and the texture was crap. Slap it in the oven with some 7-spice on any day.
I normally do stick it in the oven, I just need to start spicing it up so its nicer for work lunches
Stumbled upon this todayIt's a couple of years old but thought you guys might appreciate it if you haven't seen it already.
The change at the start is amazing...then it stays about the same, then he eventually bulks up a bit more so to speak towards the end.Got a dilemma: Had to change gym and the new gym does not have a squat/power rack just 2 smith machines. Do I continue to do my squats on the smith? Or try rig something else up?![]()
If I recall Benny squatted from the the benchpress, he got in under the bar and lifted it off, then did squats and put it back.
That depends on the benchpress though, if you're up for a little challange go for that.
How heavy do you go for squat?
Id use what you have so squat in the smith (IIRC your feet have to go a bit further forward).
Could also try cleaning a barbell up and front squatting (if you have one)
or dumbbell split squats.
