well i am keeping my 480 now as it is completely stable at the 1050v's wahooooo
Is this a replacement 480soc or not? Also, what is your card's serial number? (just the four first digits to tell the batch date).
Thanks.
No this is my first one i bought . It fails tests with occt and heaven artifacts with it at default 1025v so i was going to send it back but i upped the V's to 1050 and it is stable now
The occt i used to test is the new beta 5 OCCT 4
Temps are about the same with the increse of the v's mind you i have 2 outlet fans one above each card to draw the heat out the back and 2 x 120 fans blowing directly at the cards one on the side one blowing from the back of the cards to the back of the case and then all the prefitted fans on the HAF X case PLUS 3 fans on the rad at the top that push air through to 2 x 200mm fans at the top pulling the air OUT of the rad and out of the case
I MUST SAY THIS IS LOUD I CAN HARDLY HEAR MYSELF TYPE
But keeps quite acceptable temps
To void or not to void. That is the question
oh dear, my 580 may be faulty![]()
so whats the highest temps people are getting from the soc/se ?
sounds like these cards aren't worth the hassle
great card if you get a stable one but the chances seem too high you'll get an unstable one
how can this percentage(going on this thread) of these cards be unstable and still make it to sale?
45th week of 2010 mine was made by the way
just for referance.
! TouchDown what is your voltage !
