Caporegime
- 12 Mar 2009
More info please![]()
I wouldn't recommend first time players doing this as it will spoil the game, but if you've completed the game already and you're just after a few achievements then it's a nice way to level up quickly and get a lot of medical equipment.
Basically you go to HELIOS One which will start "That Lucky Old Sun", go and talk to Fantastic and tell him you want to help him, then go and talk to Ignacio Rivas who is in the same room, tell Rivas that you're a Follower of the Apocolypse, you can do that by using the confirmed bachelor perk, or by passing a 30 speech challenge.
Once you've convinced him you're a Follower you need to carry on playing the quest as normal, so link up the two terminals, then go into the mainframe area and repair it, you can do this either by using one piece of scrap metal and having 35 repair skill, or by having the Poseidon ID Card OR 45 Science which allows you to tell a robot to repair it for you.
Once this is done you can use the mainframe to decide where to route the power, it's important that you choose to send the power to the full region, the option that says Full Region Emergency Power Output or something like that. Once you've done that you need to go outside onto the tower and align the mirrors, when that's done you can go back to Rivas and tell him you overloaded the plant, he'll reward you with 3 Stimpaks, 2 Doctor's Bags and 385XP, if you've cleared your 360's cache and you play the unpatched version you can just keep selecting this option over and over. You'll probably be over-encumbered with Doctor's Bags because they have weight, but you can just walk to Novac and dump your stuff there.
