Has anyone bought screen protectors? If so, which should I go for/avoid?
Also, which are the best flip leather cases?![]()
Search the thread for "screen protector" and "leather case".
Ok updated properly this time, was the cable, but now I get a "the process com.android.phone has stopped unexpectedly. please try again".... great..
Is this option not under SMS settings?
KE2 is out now, Kies only at the moment though.![]()
Nope, only have a choice of pre-installed ones.
Seems odd that you can change absolutely everything else about this phone..except the SMS tones..something I could do on 5 year old handsets.
Had a missed call from 150 this afternoon, got all excited thinking that perhaps they had got it in stock. Phoned up but couldn't get through to the guy I'd been dealing with, but got another, who said tmobile won't have it for another fortnight now! Will phone again tomorrow as it seems strange for me to have a missed call for no reason.
GAH
Anyone else having this issue?? Can anyone help?? Should I reset the phone to factory defaults after doing a firmware upgrade?
Hopefully this firmware update will improve the battery, charged it yesterday and 19 hours later it's at 3% with hardly any usageDefinitely need to look into this, any light use and I'm looking at it lasting half a day at most.
I assume applying any of these updates with either kies or odin you would lose root?
set brightness to auto, trun off all those cruddy widgets that come with it, turn off wifi and gps
You sure? I downloaded a Portal 2 soundboard, and one of the options in the app is to set one of the sounds as your notification sound. Which I did.
Got one in black whilst I await delivery of my proper case, unfortunatly its that horrible cheap swade (sp) feeling that I cant stand, but want something on it to keep it good.
