- 19 Jul 2010
- West Oxon
ePeen ??
Is Virgin 50, cable only?
When I check for availability it gives me the impression, I cant get Virgind becuase Im not in a cable area.
Do 50Mb users also get this "Superhub" that Virgin Media keep yip yapping about?
Had 50MB installed yesterday as an upgrade from 20MB. My speeds were always around 19.8 before so I was really happy.
However, my speeds now are no between 7-15MB depending on the time of day I test. It did creep to 22MB this morning but that's it.
I have checked the firmware on the superhub and it's R26. I have seen people say to turn off the hub firewall and flood protection but the option seems to be missing. Was it removed with the latest firmware?
I just spoke to Virgin and they said I need an N series network card, would my G series not be ok as it is rated to 54Mbs?
Look under Services it's all still there. And it's Mb not MB
Do a speed test here http://www.speedtest.net/ and post what you get.
You will need a N card or dongle(I thought they gave you one free?)
Just saw your EDIT. Hard wire the super hub to test speed don't use wireless.
They're right (for a change). If you're downloading via a wireless G card then it'll bottleneck out at around 20mb, as you've discovered. WirelessN is the solution. It's probably worth checking your download speeds when hard wired with an ethernet cable though, just to be sure.
Guys in Newcastle. Have you been updated to 5mb upload? I've got utorrent running at the moment and I'm uploading at 500kb/s!!
