Mine atm tbh
What's that control panel type widget just above the dock? Would really like that!
Mine atm tbh
Google "x10 wallpaper"![]()
I've found that 7 screens is overkill, dragged it down to 5 now, seeing as the calendar widget isn't much use when you can just click on the BW clock's date to bring up the Sammy calendar.The more I figure out and around, the less widgets I feel I need.
mmmmmm bloody show off
thread title says: Post your mobile phone desktop!
think you want this: http://forums.overclockers.co.uk/showthread.php?t=18276588&highlight=tablet+desktop![]()
Looks like Widgetsoid. You can create your own panel with whatever functions you like, plus choose the colour and transparancy.
exactly the same herefirsts days i got my android my 5 screen were full of widgets.. now i use 3 screens and 4 widgets thorough them
I only use 3 screens with a handful of widgets. I could easily use two but I like white space. You should see my app drawer: I only have 15 listed (half the screen).
^Uncheck the "seperators" when making the widget. Will look better, unless you want it like that.
i can't decide![]()
Looks better and cleaner without the lines imo. Have a go with colours aswell, my panel is green on a dark backgound
Going for the minimalistic approach too:
Second homescreen aka "back"
