Caporegime
- 18 Sep 2009
- Dormanstown.
6.) Bulldozer isn't real.
Just a bunch of wood screws melted down into CPU shapes.6.) Bulldozer isn't real.
Apologies for my laziness but can someone please clarify when 990FX will be released? thanks.![]()
Inital reviews showed no gain
Apparently there identical to the 800 chipsets, AMD just bumped up the number to show it's AM3+ rather than AM3.
eeeeeeeEEE
any official word on the matter?
990fx has native SLI support, there's one difference, research others instead of saying crap.
Toms Hardware said:The 990FX chipset employs the same silicon as 890FX.
According to AMD, it’s incrementing the platform name to clarify compatibility with Bulldozer-based processors. When you see a board that centers on 990FX, the company wants you to know that its upcoming AM3+ CPUs are drop-in-compatible (again, 990FX-based boards will also take existing AM3 chips).
What'd you mean official word? The answer is yes, ring the AMD CEO if you want authenticity.
Cheers!
