I for one are in favor of the DRS boost hack, makes it more exciting IMO.
And this is the problem, people are happy to throw away the racing for entertainment, made worse bu the stewards investigations at every contact.
So you what time trailing, that is not racing. Dirty air is more or less solved this year anyway and can be further improved.
Stupid comment, they all build to same rules, f1 is 70% car weighted and as it should be.
F1 is racing and you can get the spectacle without removing the racing. In fact fia already have solved the problem by 50% in one simple rule change.
It's solved by double diffuser ban, the following gap is now down to 0.5seconds. It is not a huge disadvantage at all, more than close enough for a slipstream.
That solves the disrupted airflow over a front wing during a fast corner does it?
Clueless springs to mind, half a second is 45 metres at 200mph how is that close enough for a slipstream?
It can't be argued either. Way. It doesn't matter if it's. On all cars, only one car can use it, the one behind.
Doesn't that break the fundamental that the car in front becomes the car behind the next lap? Then they can just repay the favour?
Good race good result long wait...
As an aside AcidHell2 I wish you wouldn't post using your crApple product as it makes out your a 7 year old with it's autocorrect "feature"
That sentence makes no sense whatsoever![]()
Trust me it's no better on a pc. Rather than auto correct, it's just eligible instead.
at 200 coming out of a corner, that's some exit speed.
There has always been dirty air. Every time you punch something through air, you create dirty air. It's nothing new in f1 it's just since the mid 90s it's been getting worse and worse, till the last couple of years, where they have reduced it and with double diffuser ban, they halved it in one swoop.
No action taken by stewards over Button/Alonso collision.
Still leaves the Button/Hamilton incident
