Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Is claying your car important/necessary before polishing?
Other than washing your wheels, did you clay them as well to take the existing tar before sealing them?
Yes, especially when machine polishing. Otherwise you're just rubbing contaminants in to the paint causing swirling & scratches.
If you think your car is clean give it a going over with a clay bar and you'll be surprised. It's worth doing if you're polishing by hand anyway. Won't take more than an hour or 2 depending on how anal you are with it.
I use AG E&M on my wheels to help break through grease and dirt. Combined with polished and properly protected (poorboys wheel sealant) wheels it makes them a pleasure to clean. Stuff stays on for ages. I did my wheels last August with 2 or 3 coats and I've only got a few bits of tar bonded on. The rest cleans up beautifully.
I used WW before hand to clean them up as they were a right mess and my tar remover wasn't doing much good.
Mine had a bath yesterday...
Done, for some reason the passenger door was about 5 times dirtier than the driver's door?!
4 hours of washing, claying, washing again, polishing, washing again, waxing later....
Thanks...I'm holding off getting a polishing machine, but looking at some of the results that people are achieving I don't know how long I can hold out![]()
Nice one Raymond, looks fantastic. It's a slippery slope mind, a bit like photography, you'll keep trying to get an even better finish with a variety of products and then when you think you've found the perfect combination you'll be forever trying to keep it clean (especially as it's black).![]()
Hate to spend £20 on a bottle of something else and hate it and go back to AG again.
Note to self:-
Do Not wash Microfibre clothes at 60c
I thought to make sure I get rid of the polish, dirt and what not on it I put them in a 60C wash....they came out 25% of their original size!
Note to self:-
What Polished Bliss say to do is:
Wash after each use in a washing machine at a low temperature (40 °C) using a non-biological liquid detergent (avoid soap powders and detergents containing bleach or fabric softeners). Allow to dry naturally on a line or tumble dry on a cool heat setting (avoid radiators and other sources of high heat).
Note to self:-
Too late....
Use them for the wheels or other grubby tasks?
I usually wash them at 30degrees straight away ( 'Silks & Accessories') comes out clean no problems.
